Conversion - Mk4 Petrol - OUT, Mk3 Diesel IN
Postby Luke » Thu Feb 22, 2007 7:10 pm
CK0505 wrote:Also, where does the glow plugs get their power from? Might sound a silly question, but I have no clue.
no glow plugs on a Di :D
if you arnt getting fuel out of the injectors have you put the fuel lines on the right way round :?: easy mistake to make :lol:
Postby CK0505 » Thu Feb 22, 2007 9:05 pm
Thanks Luke and MrM for your replies.
I gotta say..... maybe I haven't bled them right. In my Haynes manual it just says to push the hand pump slowly for 20-30 times slowly. Is this the right way to bleed the system?
Also, how does the engine make an ignition?
As I mentioned earlier I am not the sharpest tool in the box when it comes to diesel engines.
CK0505
Postby MrMPuk » Thu Feb 22, 2007 9:10 pm
Bleeding a Di.
Make sure the filter is fuel with clean diesel.
Then get somemone to turn it over while you crack the injector pipes one at a time until you get a decent squirt of diesel with no bubbles in it.
Postby Guy88 » Thu Feb 22, 2007 9:14 pm
A diesel engine works by compression ignition
Basically as the engine turns it only draws in air. next it compresses it 20:1 (1/20th of its original mass) this generates a lot of heat. then the injector fires spraying a fine mist of diesel into the combustion chamber of the piston crown (direct injetion) this then ignites and forces the piston down
Indirect is slightly different :wink:
To bleed. crack of the injector pipes and crank it over. when you got diesel there tighten them beck up and it should start :wink:
All a diesel needs is air fuel and compression. this is why diesels can run under water as long as the intake is above the water :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Fri Feb 23, 2007 7:43 am
Guy88 wrote:All a diesel needs is air fuel and compression. this is why diesels can run under water as long as the intake is above the water :D
Well old diesels yes, I'd like to see you do that with any new diesel engine!
Postby CK0505 » Fri Feb 23, 2007 10:20 am
Now I understand. Thanks for the explanation. I'll get the other half to help later today.
CK0505
Postby Guy88 » Fri Feb 23, 2007 10:23 am
This is the problem with the TD5 Defender :x the water runs down the loom and shorts out the ECU :shock:
I prefer to be ablt to press a pedel or pull a lever and see somthing move at the other end :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby CK0505 » Fri Feb 23, 2007 3:44 pm
Well it looks like the fuel pipes are the wrong way around. I dropped the tank and started to change them over when I pulled on of the connecting ends of the fuel pipe..... and do you think I can get it back on, can I heck!!! got covered in fuel and not a happy bunny at the moment. Patience is wearing a bit thin now.
Anyway, that's enough for today, I gotta go drive a limo later. Back to the van on monday. If anyone has any ideas how I can get the pipe back on please let me know.
I suppose I could heat the tube up in some hot water to make it a bti pliable first.
CK0505
Postby CK0505 » Wed Mar 07, 2007 6:00 pm
OK, enough is enough. I cant' get this sorted. SO the van is now up for sale in the sale section.
If no interest then it's gonna be scrapped. Thanks to everyone that has given me advice. I just have not got the time, money or interest in fixing it. I'll stick to what I know and leave the vehicle repairs to the pros.
CK0505
