6wheelers 190lwb
6wheelers 190lwb
Postby 6wheeler » Sun Jun 01, 2014 10:19 pm
Thought I might start a progress thread on my mk5.
Here's more or less how I got it, bought it to move some heavy machinery which it did well. Now it'a rather surplus to my needs ... but I have just bought a new house that needs work and a tipper would come in handy :)
So got myself an alloy tipper body from a MK4 with pump and ram etc. The tipper chassis was sound, but the tipper steelwork was well rotten. The whole lot was dismantled to salvage the good bits.
So the flatbed was unbolted and taken off. Christ it was heavy, much heavier than expected! It felt heavier than the tipper bed I just removed off the mk4? Anyways, here's a pic of some steel stips cut, drilled and bolted to the bed ready to have the chassis welded on.
welded :D New steel laid out.
It was damned hot in the full sun, so put this up for some shade
The rear hinge brackets were salvaged of the old bed, cut off and cleaned up but the pivot bush was in a bad way as one side was rusted badly. So on the milling machine to be bored out back to some clean steel.
Now the hole is of course now too big, so an inset is needed
6wheeler
Re: 6wheelers 190lwb
Postby 6wheeler » Mon Jun 02, 2014 12:34 pm
The next piece is part of the ram scissor swivels on the top body. I destroyed a couple of punches trying to drift the securing pins out and had to resort to a hack job leaving a bit of a mess.
So insert bar with a brass shim, the brass will leave some clearance when removed as the repair weld will shrink the boss around the bar. Also the weld won't stick to the brass so I won't weld the bar permanently !!
All welded up and cleaned up, brass shim removed ..
6wheeler
Postby 6wheeler » Mon Jun 02, 2014 10:58 pm
coming along now,
6wheeler
Postby MinorMatt » Tue Jun 03, 2014 11:38 am
Looks like you are doing a proper job there :)
I want a mill :evil:
(I already have a lathe, but its a bit wobbly!)
Postby 6wheeler » Sat Jun 07, 2014 4:54 pm
Yes a mill is well handy to have after you get a lathe.
Tada !
6wheeler
Postby karl » Sat Jun 07, 2014 9:31 pm
As above a top job their keep those pictures coming mate
Tipper ?
karl
Tranny Lover!!!
Postby 6wheeler » Sat Jun 07, 2014 9:43 pm
Yes tipper, and a flat bed at the same time. I have made the front posts removable like the rears. The bed is 10ft and I left 18" clearance to the cab giving 11.5ft for a car to sit on. The main frames are left open at the rear, plastic caps will be fitted, to allow a short extension to be removable, maybe beaver it too, haven't got that far in my thinking yet.
6wheeler
Postby BUNGAL » Sun Jun 08, 2014 3:20 pm
Why can't I see any pictures?
BUNGAL
Postby 6wheeler » Sun Jun 08, 2014 3:48 pm
cos you're from Bristol ....
No idea, there's no restrictions on the hosting?
6wheeler
Postby 6wheeler » Thu Jun 12, 2014 9:13 am
Base frame removed to weld underneath the mounting strips
While that was off I decided to wire brush the truck chassis with the angle grinder. This was done with some trepidation as i was expecting holes everywhere after shifting the flakey paint and rust. However it was found to be in surprisingly good condition.
Except for here on the passenger side .. the drivers side was ok.
After wire brushing the top half was painted with POR15 rust paint ... I've been using this for around 25yrs and it works .. unlike just about every other rust paint I've tried over the years. I still have items I painted with this sat outside with the paint still on...
Of course I had plenty of help from the newest family member .. it's a life init :D
6wheeler
Postby bigjohnthomas » Thu Jun 12, 2014 9:18 am
BMD top pic?
bigjohnthomas
Postby 6wheeler » Thu Jun 12, 2014 9:21 am
BDM .. sorry you've lost me?
6wheeler
Postby bigjohnthomas » Thu Jun 12, 2014 9:28 am
no not bdm a bmd :lol:
bernese mountain dog :lol: :lol:
bigjohnthomas
Postby 6wheeler » Thu Jun 12, 2014 9:36 am
Lol, no he a Heinz special and a very good dog with other animals, keeps an eye on the chickens all day and night ... the pup is a Welsh Collie cross Austrailian Kelpie
6wheeler
Postby BigMonty » Thu Jun 12, 2014 7:36 pm
Going to live up to your name and stick another axle on it. That would be way cool. :D
oh hang on then you would be tenwheeler, sorry the raspberry vodka must be taking effect.
BigMonty
