Automatic climate control set
Re: Automatic climate control set
Postby Meyer automotive » Sat Oct 25, 2014 10:19 pm
I thought I made a mistake somewere, but mine does that to, for some reason it switches back to 22 degrees?
Ford transit Custom, 270 125 hp L1H1 double cab fully loaded, lowered, chipped 190 hp, egr and dpf off, 487 nm torque. And special design leather interior grey with black piping and stitches.
Meyer automotive
Location: In car electronics, in house LED light specialist, domotics
Postby 75124 » Sat Oct 25, 2014 10:52 pm
Meyer automotive wrote:I thought I made a mistake somewere, but mine does that to, for some reason it switches back to 22 degrees?
mine does the same...specially if I select the AC off...after some minutes it turns auto 22°...not a big problem...but I wonder why?
Tourneo Custom black panther 155 ps
Postby BRAVO9992 » Sun Oct 26, 2014 2:57 am
So if you're driving and you set it to a low temperature, say 17'C, it just suddenly changes to 22'C without anyone touching it?
BROWNWIRE ELECTRICAL
290,155,L1,MidnightSky,Limited
BRAVO9992
Postby Alar » Sun Oct 26, 2014 7:57 am
Well, I like to keep it at 20, AC on, but somehow it jumps back to 22. It happens on daytime, last night I drove around for hours and it kept the 20 I chose
125ps 310LWB Trend Powerty Edition
Alar
Postby BRAVO9992 » Sun Oct 26, 2014 2:46 pm
Alar wrote:Well, I like to keep it at 20, AC on, but somehow it jumps back to 22. It happens on daytime, last night I drove around for hours and it kept the 20 I chose
Where did you buy your kit from?
Is there possibly a button stuck in that makes it reset or something?
BRAVO9992
Postby Alar » Sun Oct 26, 2014 2:56 pm
Mine was installed by a local dealer and as it happens to many then its seems to be more common issue
Alar
Postby Tran59 » Sun Oct 26, 2014 3:18 pm
I'll have to check mine. If it does the same I might as well have stuck with the manual version :(
The best mods are the ones you don't see
Tran59
Postby BRAVO9992 » Sun Oct 26, 2014 3:53 pm
Tran59 wrote:I'll have to check mine. If it does the same I might as well have stuck with the manual version :(
Where did you buy yours from mate?
BRAVO9992
Postby Treespotter » Sun Oct 26, 2014 11:07 pm
Mmmm. Asked for an estimate last week at the dealer. Think I'll hold off for a moment and stick to the manual.
Treespotter
Postby Tran59 » Mon Oct 27, 2014 5:54 pm
Local Ford dealer in France.
I'm sure a software update could fix this 22° bug.
Tran59
Postby Alar » Tue Oct 28, 2014 7:29 am
So just noticed what it does. It shuts it self down for about 2 seconds and when it starts up, its 22c. Well done Ford, another "working" solution :)
Alar
Postby Meyer automotive » Wed Oct 29, 2014 10:49 pm
Mine did this morning it was at 24, after 3 kilometres it changed, then the entire day nothing changed it kept the 20 degrees I've set. At the end of the day after a 1,5 hour drive it suddenly changed again.
And then something likewise, I've noticed that it seems to be off temperature, if I select 24 with outside temp 14 degrees it should get warm when the engine is warm but it suddenly thinks I need cooling ?
Meyer automotive
Postby Alar » Thu Oct 30, 2014 8:06 am
At least my aux heather works now, windows were de iced and cabin warm. So one problem has changed to another :D
Alar
Postby Tran59 » Thu Oct 30, 2014 3:03 pm
I took my van to the dealer's yesterday to show them the 22° bug, but of course it refused to do it. I drove back home and everything was ok, but today it's started resetting to 22 again :evil:
Tran59
Postby Tran59 » Thu Oct 30, 2014 4:32 pm
Covered the incongruous chrome strip at the top with a bit of carbon fibre wrap. Not a fan of CF in general, but it's the closest I had to satin black.
Tran59
Return to Transit Custom
