DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby davew2 » Thu Jan 01, 2015 9:08 pm
Griffcbr wrote:Hi would somebody be able to check details of this before I buy it please GU06 EBA
Transit 2000-2006, 2.0L Duratorq DI (85PS), Dark True Blue
VIN Number: WF0VXXBDFV5R54149
Registration Number: GU06EBA
First Registration Date: 08.03.2006
Registration Country: GB
Primary Features
Build Date: 18.06.2005
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 260S Series
Engine: 2.0L Duratorq DI (85PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Dark True Blue
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
LH Sliding Side Cargo Door - Low
With Hinged Rear Loading Doors
Southampton Plant Built
Less SVO Application/Label
Less 2nd Row LH Side Window
With Rear Blanking Panel
Less Heated Rear Window
Less Header Mounted Package Tray
With Partial Headlining - Moulded
With Roof Height Feature Pack 1
With Door Map Pocket
With Front Roof Grab Handle
With Load Space Tie Down Loop
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Rear View Mirror
Large Head/Short Arm Mirror
Passenger Lrg Head/Short Arm Mirror
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
With Door Dead Locks
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
With Driver Air Bag
With Spare Tyre Security Package
195/70R 15C LI 100/98 BSW
Any Brand Tyre Vendor
Less Engine RPM Control
Cold Start Up To -20%c
4 Wheel Anti-Lock Braking System
With Sngle.L/B Dvr/Dual L/B Pass.St
With Manual Clutch
With Recirculating Heater
With MPH/KMH Speedometer
With Radio Pre-Equipment Pack 1
6000CD RDS EON
With Load Compartment Lamp
With Manual Headlamp Leveling
If it ain't got leaf springs it in't a commercial
davew2
Postby Griffcbr » Sat Jan 03, 2015 8:49 am
Thanks very much :)
Griffcbr
Postby TimS » Sun Jan 04, 2015 2:01 pm
Hi
Could someone please check the details of my Transit CN06 EXG
TimS
Postby SCANIAMAN » Mon Jan 05, 2015 2:13 pm
Hi everyone, can somebody give any info for this PO56HDF just got it and know nothing about it
Thank you ;)
'OWNER OF VINTAGE HAMMERITE PAINT ! .........not that weak new rubbish '
' JUST ME AND MY DOG TOMMY VAN DAMAGE'
SUPPLYING PROTECTION DOGS FOR OVER 2 DECADES
SCANIAMAN
Postby 9690harrison » Mon Jan 05, 2015 8:02 pm
Etis plesse. Vk53 ymt.cheers
9690harrison
Postby davew2 » Mon Jan 05, 2015 8:09 pm
9690harrison wrote:Etis plesse. Vk53 ymt.cheers
Transit Connect 2002-, 1.8L Duratorq TDCI (90PS) - Lynx, Moondust Silver (Metallic)
VIN Number: WF0UXXTTPU3J36***
Registration Number: VK53YMT
First Registration Date: 13.11.2003
Type Approval Number (TAN): E1*2007/46*0272
Primary Features
Build Date: 05.09.2003
Vehicle Line: Transit Connect 2002-
Cab Style: Extended Van
Series: 900 Series
Engine: 1.8L Duratorq TDCI (90PS) - Lynx
Transmission: 5-Speed Manual Trans - MTX75
Drive: RHD FWD
Axle Ratio: 4.06
Territory: (+)"GB"
Paint: Moondust Silver (Metallic)
Interior Fabric: B-C Escher / Dark Flint
Minor Features
With Full Partition - Steel
LH Sliding Side Cargo Door - High
Otosan (Turkey) Plant Build
Marketing Level 4
With Power Front Windows
With Solar Tinted Glass
With Heated Windscreen
With Standard Overhead Console
Rear Door Pocket Stowage
With Load Floor Full Rubber Mat
Bodyside Moulding - 1PC BOW
Drivers Power Heated Convex Mirror
With Pass Convex Elec/Heated Mirror
With Driver 8 Way Mnl.Seat Adjuster
With Heated Washer Jet
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
6J x 15 Steel Wheel
Partial Wheel Covers
Standard Front Seat
With Anti-Theft Alarm
6000CD RDS EON
With ICE Feature Pack 13
With 2 Speakers
With Column Stalk Radio Controls
With Front Fog Lamps
With Header Mounted Map Light
©Copyright, Ford Motor Company 1994 - 2014 | Privacy Policy
davew2
Postby davew2 » Mon Jan 05, 2015 8:10 pm
SCANIAMAN wrote:Hi everyone, can somebody give any info for this PO56HDF just got it and know nothing about it
Thank you ;)
need vin on this one
We are sorry, but no information could be found for the VIN/Registration number you entered - PO56HDF
davew2
Postby davew2 » Mon Jan 05, 2015 8:11 pm
TimS wrote:Hi
Need vin on this We are sorry, but no information could be found for the VIN/Registration number you entered - CN06EXG
davew2
Postby SCANIAMAN » Mon Jan 05, 2015 8:17 pm
Thank you ;)
We are sorry, but no information could be found for the VIN/Registration number you entered - PO56HDF[/quote
Is this normal or have I got a Lemon ?
SCANIAMAN
Postby 9690harrison » Mon Jan 05, 2015 8:18 pm
Cheers dave
9690harrison
Postby davew2 » Mon Jan 05, 2015 8:50 pm
SCANIAMAN wrote:
Thank you ;)
this some times happens if its had private plates or not been registered through a dealer if you want to pm your vin i can check it again
davew2
Postby SCANIAMAN » Mon Jan 05, 2015 9:03 pm
Is this normal or have I got a Lemon ?[/quote] this some times happens if its had private plates or not been registered through a dealer if you want to pm your vin i can check it again[/quote]
Its not here right now but will when I get access, just want to thank you for your time and help Appreciated ;)
SCANIAMAN
Postby ake » Mon Jan 05, 2015 9:06 pm
None of our first batch of MK7 vans appeared on etis by reg number, the dealer forgot to register them!
Postby SCANIAMAN » Mon Jan 05, 2015 9:28 pm
ake wrote:None of our first batch of MK7 vans appeared on etis by reg number, the dealer forgot to register them!
Thanks for that ! sort of eases my mind ;)
SCANIAMAN
Postby TimS » Mon Jan 05, 2015 9:41 pm
davew2 wrote:
TimS wrote:Hi
Hi, had this come up a couple of times when buying parts from main dealer where I had to give the vin as reg number didnt bring it up, never did ask why.
VIN is WF0LXXTTFL5D45911
TimS
Users browsing this forum: Google [Bot], samc1992, STEVE P
