hill start
Re: hill start
Postby loot » Thu Jan 15, 2015 11:47 pm
Punto443 wrote:Don't think I'll get an abs pump doon the trousers :lol: but there usually pretty good in there :D
If you put it down the back and say you've had an accident they won't ask questions :lol:
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Fri Jan 16, 2015 7:03 pm
Well I've just bought an abs pump off eBay 45 pounds and mr punto scored a lat sensor, thanks matey 8)
There's a chance my pump just needs the right calibration only, there's a chance that the pump is different internally (can't see how tho maybe the module doesn't have the right level components similar to the bcm carry on/although i believe the abs pump restricts the wheels that are spinning as in esp) so you could assume reasonably that the abs pump i have is already equipped to do hsa :?
I decided that 45 pounds was worth a gamble :o
Hopefully now I'll have everything needed to get this mod done :mrgreen:
07 350 170ps
Ids map here
loot
Re: hill start
Postby paul2012 » Fri Jan 16, 2015 7:14 pm
loot34 wrote:Well I've just bought an abs pump off eBay 45 pounds and mr punto scored a lat sensor, thanks matey 8)
What's the part no on pump you've purchased ?
As said previously there 2 types of EBS/EPS pumps one for FWD & the other for RWD :?
A yes when programming use vin no from vehicle that ahs ABS/ESP with HSA
(Much sure vin no is the same on all modules)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: hill start
Postby loot » Fri Jan 16, 2015 7:39 pm
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Fri Jan 16, 2015 7:42 pm
Rwd it is :-)
Any idea why fwd and rwd pumps are different? I can't see why they need to be :?:
07 350 170ps
Ids map here
loot
Re: hill start
Postby blue estate » Fri Jan 16, 2015 7:49 pm
P/m'd you a little message that will help you :wink:
MGS5 and MG5
VOLVO FH daily drive
blue estate
Re: hill start
Postby paul2012 » Fri Jan 16, 2015 7:53 pm
loot34 wrote:Got this 1 Paul :-)
http://m.ebay.co.uk/itm/191446850866
That pump fits RWD from 2007-2011 :D
paul2012
Re: hill start
Postby loot » Fri Jan 16, 2015 8:01 pm
Cheers blue 8)
Fingers crossed Paul eh :-)
Might take my remapped pcm off and install the standard 1 for this operation, probably be OK but backup data on bcm/pcm and clocks, and all 3 are from different vehicles :lol: hope i don't get a message in ids "well i don't f*ckin know what you want me to do! " :lol: :lol:
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Sat Jan 17, 2015 3:07 pm
Had a panic attack today lol, got my lat sensor off mr punto thanks :-)
Thought i best check mine to make sure they aren't the right ones.
Phew new 1 is 8c11 :-)
Couldn't read the abs but I'll assume it is also 6c11 :o
07 350 170ps
Ids map here
loot
Re: hill start
Postby loot » Sun Jan 18, 2015 5:03 pm
Right, the plop thickens, i fraudified the van and installed a new module but never, didn't have the option to update the module info so i think that these are install only and based on the hardware plus configuration, i also learned vin data, and configured steering sensor etc OK but couldn't do the lat sensor or activate hill start :-(
I then installed puntos lat sensor and got this.
Missing message is saying that the abs module isn't equipped with the right program to communicate fully.
Options are to fit my new abs when it arrives but then i hope that is it.
What i didn't do tho is unplug the abs module then load ids and install a new module, abs then fill in info if that is what it does?
Tbh it's too cold to mess about, currently the abs lamp is on, i just hope that the airbag doesn't shoot me over the seat on the way to work :shock:
07 350 170ps
Ids map here
loot
Re: hill start
Postby paul2012 » Sun Jan 18, 2015 6:31 pm
loot34 wrote:Right, the plop thickens, i fraudified the van and installed a new module but never, didn't have the option to update the module info so i think that these are install only and based on the hardware plus configuration, i also learned vin data, and configured steering sensor etc OK but couldn't do the lat sensor or activate hill start :-(
When you get ABS/PUMP.
Once fitted, on IDS go to module programming & program pump I first. Then calibrated all sensors including SAS (Steering angle sensor) :wink:
paul2012
Re: hill start
Postby loot » Sun Jan 18, 2015 7:10 pm
The only option for pump was new module installation, no update option, only pcm, bcm, ipc :-(
I will unplug my abs then install the new 1 and hope that it is just going to install the new 1 with its added functionality?
Fingers crossed :-)
07 350 170ps
Ids map here
loot
Re: hill start
Postby paul2012 » Sun Jan 18, 2015 7:32 pm
loot34 wrote:The only option for pump was new module installation, no update option, only pcm, bcm, ipc :-(
Fingers crossed :-)
Yes as new module installation. Hence the reason to use vin no from a vehicle that has everything already on it 8)
paul2012
Re: hill start
Postby blue estate » Sun Jan 18, 2015 7:34 pm
Fingers crossed :-)
Like from a 2010 plt Jumbo that's bean cans now :wink: :lol: :lol: :lol:
MGS5 and MG5
blue estate
Re: hill start
Postby paul2012 » Sun Jan 18, 2015 7:38 pm
Fingers crossed :-)
Like fro a 2010 plt Jumbo that's bean cans now :wink: :lol: :lol: :lol:
Yes, that would be perfect :wink:
paul2012
