horn not working ...common issue ??
Postby maccavvy » Tue Feb 03, 2015 8:50 pm
only had my van a few weeks. some douche pulled out on me today and gave him a blast... or I would've done if it worked.
it does sound for the alarm.. any common thing I should be looking at . does it have a separate fuse or relay for horn push ???
Mk8 310 trend FWD and a 5.7 ls1 monaro RWD
maccavvy
Re: horn not working ...common issue ??
Postby Backbone of Britain » Tue Feb 03, 2015 8:55 pm
You don't say what van but clock spring Could have failed.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby maccavvy » Tue Feb 03, 2015 9:16 pm
sorry 2010 2.4 rwd ..ps whats a clock spring.
maccavvy
Postby Backbone of Britain » Tue Feb 03, 2015 9:20 pm
maccavvy wrote:sorry 2010 2.4 rwd ..ps whats a clock spring.
It's a circular piece of spring steel that makes and breaks contact when you activate the horn push. Located in the steering wheel under the airbag I think.
Backbone of Britain
Postby CROSSFIREROB » Tue Feb 03, 2015 9:34 pm
Mine was just a blown fuse.
Rockin and a rollin all day long !
CROSSFIREROB
Postby Wadey » Tue Feb 03, 2015 9:37 pm
Uv changed loads of horns depends on where it's been they normally fill up with water it's in front of the NSF wheel Id check you have power there first
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby maccavvy » Tue Feb 03, 2015 10:06 pm
Near the washer bottle ??? I'll. Get test Meter out and check fuses
Is the alarm the same horn ?
maccavvy
Postby motorman116 » Tue Feb 03, 2015 10:12 pm
:?: :?: The horn on my 07 350 is on the drivers side, in the engine bay on the inner wing. Very easy to get to once the headlamp is removed...
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby Wadey » Tue Feb 03, 2015 10:29 pm
Yea sorry I was thinking mk6 mk7 is down on the inner wing drives side like Norman said take the he's light out my mistake '
Wadey
Postby maccavvy » Tue Jun 23, 2015 5:59 pm
horn has no power going to it.. earth is there. but no power.
steering wheel off time ???
maccavvy
Postby loot » Tue Jun 23, 2015 6:56 pm
check fuse f48 5A in the glovebox fusebox (ajb) and also see if relay r14 is clicking when you press the horn on the wheel, if not, Take the lower steering plastic cowl off and you'll see a connector at 6 o clock, unplug it and you'll see it has 1.........9 you need to bridge pins 6 and 7 on the connector to activate the horn.
If the relay is clicking then the problem is the wiring from the relay to horn.
On mk7 the switch activates the negative side of the relay built into the bcm which sends live power to the horn relay which activates the positive side of it, the horn has a negative and the squib has a negative, bcm internal positive kl30 bus and fusebox r14 positive relay.
07 350 170ps
Ids map here
loot
Postby knobby1 » Tue Jun 23, 2015 8:55 pm
C'mon Loot....It'd be easier to hang a cat out the window and squeeze it's neck a bit... :lol:
Postby loot » Tue Jun 23, 2015 9:05 pm
Most things are :lol:
07 350 170ps
Ids map here
loot
Postby knobby1 » Tue Jun 23, 2015 9:11 pm
loot wrote:Most things are :lol:
LOL... :mrgreen:
Postby maccavvy » Thu Jun 25, 2015 7:35 am
checked fuse.. tests fine..
ill check said relay and connector when I get chance over next few days.. thanks
maccavvy
Users browsing this forum: northernboy, Rollingbob, samc1992
