mondeo 130ps into mk6
Postby sly443 » Sun Feb 08, 2015 5:41 pm
Hi just got mondeo 2004 2.0 tdci 130ps planing to put all engine gearbox into my Transit.
Any suggestion.
sly443
Re: mondeo 130ps into mk6
Postby jay » Mon Feb 09, 2015 11:47 pm
mondeo 6 speed box?? you might need to change your driveshafts..
are you planning on using your wiring loom and ecu and pump? is yours a tdci already or tddi proberbly going to have to change your loom and bodge the mondeo loom to get everything working(basically a lot of work)
mk1 connect tourneo
jay
Postby paul2012 » Tue Feb 10, 2015 4:25 pm
It can be done, although there's a lot of rewiring to do.
Unfortunately not a straight swap..
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby wojciech » Tue Feb 10, 2015 4:45 pm
paul2012 wrote:Unfortunately not a straight swap..
If only engine swap - without gearbox - it isn't problem. If Transit is tdci - it will work good with Transit PCM. Will necessary coding injectors from Mondeo into Transit PCM only.
wojciech
Postby sly443 » Tue Feb 10, 2015 6:58 pm
hi its 2001 year tddi want to fitt all engine gearbox swap wiring loom ecu. i know its difficult but wil do it or try. Bigest problem for me is gearbox do you thing can put transit mk7 driveshaft or must cut and weld.
sly443
Postby wojciech » Tue Feb 10, 2015 8:31 pm
Did you think about halfshafts? They are different in Mondeo and Transit.
Second thing - total ratio for Mondeo is to fast for Transit.
You are looking for big straits - I think... :roll:
wojciech
Postby angeleye » Wed Feb 11, 2015 1:36 am
Search winterheating threads as he done a mondeo doner engine.he had to make up some driveshafts .. not sure if it was a tddi.tdci or whole thing with loom.but he did go to france in it after it was done......wonder where winterheating got to
angeleye
Postby bigjohnthomas » Wed Feb 11, 2015 5:36 am
He went off studenting last I heard :?
bigjohnthomas
Postby sly443 » Fri Mar 27, 2015 3:19 pm
Mondeo interior striped just fighting with all wiring. Checked and as said lots of extension to be done. Just thinking of fiting mondeo heater box so can use aircon
sly443
Postby coacher » Fri Mar 27, 2015 8:42 pm
Ive got a complete heater from an '04 transit with AC, it's still got the pipework attached. make me an offer.
coacher
Postby sly443 » Tue Jul 07, 2015 6:33 am
All fitted working only problem with seatbelt pretensioner not fitted from mondeo Anyone how to disable to switch of airbag light
sly443
Postby paul2012 » Tue Jul 07, 2015 1:06 pm
sly443 wrote:All fitted working only problem with seatbelt pretensioner not fitted from mondeo Anyone how to disable to switch of airbag light
You can't disable airbag light. It must prove out for MOT (lights up when ignition is switch on then goes out).
I assume you're using Mondeo mk3 instrument cluster :?:
paul2012
Postby sly443 » Thu Jul 09, 2015 7:16 pm
Yes airbags sensor working just there is no pretensioner so heard can put resistor anybody know how to
sly443
Postby sly443 » Fri Jul 17, 2015 1:55 pm
Thanks sorted just fit pretensioner from mondeo. Next problem abs sensors from mk6 not working fitted mk7 OK but speedo reading 10 MPH less anyone know how many teeth on abs ring in mk7
sly443
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot], Martinivanman
