Mk7 BE RCM Please
Re: Mk7 BE RCM Please
Postby Airthies » Tue Apr 14, 2015 12:10 am
Hey loot, would your's not be bringing up B2477 as well if you've tried reprogramming them? I managed to get all airbag an restraint circuit faults to disappear by adding in fused 2.8ohm resistors into the circuits at fault but it appears that once activated you can't clear B2477...
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ake » Tue Apr 14, 2015 6:58 am
Side curtain airbags are seat mounted, on, if I remember correctly, GLX spec Transits, Early sport vans with cloth seats, not sure about limited spec vans, or sports with leather
Postby Appy » Tue Apr 14, 2015 7:19 am
It is looking likely that I'v reprogramed the rcm , I had previously opened a session on ids with the intention of turning off the locking failure warning horn, but I could not find the menus on the module programing selection,I always thought my version of ids seemed a bit sparse with the menus and I don't always find what Im looking for which has me clicking through different sections....... . when I get it on ids again (after an update ) Im expecting to see the rcm is configured wrong. I also tried to clear the codes with a generic type reader but made no difference.
but feeling a little happier that the underlying fault was me rather than a problem on the system; I hav'nt rung Ford yet, I'm not sure I want to ! I think I'll wait till Ive sourced another.
thanks for for the pointers guys, its been a great help. Airthies Howto is exactly what I need. SPOTON
colin
Appy
Postby loot » Tue Apr 14, 2015 7:53 am
Airthies wrote:Hey loot, would your's not be bringing up B2477 as well if you've tried reprogramming them? I managed to get all airbag an restraint circuit faults to disappear by adding in fused 2.8ohm resistors into the circuits at fault but it appears that once activated you can't clear B2477...
Quite right, i mistook your fault as comms error when it is actually config error :oops:
Question is tho, if he has twin air bags then how can the rcm be reprogrammed differently lol, i would have thought it would reprogram it to what it already is?
It's a setting that is fast becoming a pointless option i think lol.
07 350 170ps
Ids map here
loot
Postby Appy » Tue Apr 14, 2015 9:15 am
While ids was updating I checked the handbook, side airbags are installed in Seat back, which I definately dont have. just Driver and passenger.
With 86.04 running plugged in the vcm and found this
went to the toolbox menu
and still cannot open module programing
I continue to get the same message.
the Ids info is, v 86.04 VCM 11 pc software version 2.1.1.5 and it shows device software version
Appy
Postby loot » Tue Apr 14, 2015 10:06 am
Did you run my xprog?
07 350 170ps
Ids map here
loot
Postby Appy » Tue Apr 14, 2015 10:30 am
Hi loot that link takes me to one file labeled " IDS-86.04 update.zip
17 days ago · 20.91 MB" which I downloaded and installed, didn't see any thing named xprog
I have since found the MENU to RCM programing via the 'Electrical ' menu which advises checking DTCs first.
The re configure failed. At the moment loot I'm waiting on a replacement mod. so I've really no urgency to sort ids, (but I would really like the module programing at some point)
perhaps I need to get the config files loaded first
and then I found a further code B10A2 (which cleared)
Im not sure this is relevent ... Im thinking Ive probably been a bit rough handling the module,
Appy
Postby loot » Tue Apr 14, 2015 10:44 am
Try this
https://www.dropbox.com/s/ambejkulcj4dk ... g.zip?dl=0
I doubt you'll reprogram the rcm:-( good luck tho :-)
07 350 170ps
Ids map here
loot
Postby Appy » Tue Apr 14, 2015 11:12 am
Another thank you loot, the programing menu now opens up. I tried to reprogram but as now expected it fails, it gave me a message that programing was only for New Modules.
I shall sit tight and await a module, at least now I am confident I have the tool to clear crash data if I need.
I'm also hoping to now turn of the 'failed lock' Horn (Ive a sticky lock on the back door to sort )
Cheers guys, all your input has been great
colin
Appy
Postby loot » Tue Apr 14, 2015 11:28 am
Module programming-config (under reprogram)- config parameters (above special function)- top option download vehicle config-3rd option (modify config)- torn things on and off as you please - upload vehicle config.
When this thread is concluded, can i move it to a more appropriate party of the forum?
Bit mad being in the wanted section lol :o
07 350 170ps
Ids map here
loot
Postby Trannyjohn » Sat May 16, 2015 1:54 pm
Loot I'm still having the same problem
Trannyjohn
Postby Trannyjohn » Sun May 17, 2015 7:03 pm
Loot I have had 3 trouble codes 1 relating to passenger airbag 2 passenger pretensioning and the third one RCM module wants reconfiguring i've been to Maplin and got a 2.8 ohms resistor with a two amp fuse solded them together and plugged it in now I only have two trouble codes which being the pre-tensioner and a reconfigure of the RCM but MOT due this week so I have took the clocks apart and put a bit of black tape over the light so I have no light on the dashboard now so hopefully it should pass its MOT
Trannyjohn
Postby loot » Mon May 18, 2015 9:00 am
Lol result :-)
If you are down this way the breakers here mcghills sell the rcm for 30 pounds. :-)
07 350 170ps
Ids map here
loot
Postby Trannyjohn » Mon May 18, 2015 12:26 pm
Dam I was in Wales on Friday delivering
Trannyjohn
Postby loot » Mon May 18, 2015 2:22 pm
Next time you are down bring a 10mm socket and a 30 pound note and your good to go :-)
07 350 170ps
Ids map here
loot
