replacing fuel filter on a mk7
Postby tippermad » Sat May 16, 2015 11:59 pm
does anyone know where the bleed screw is and how can i bleed it someone says fill the new filter full of fuel and screw it back on and then turn over when starts rev it for a few minites or do you open the water drain screw and bleed it that way pllz help thanks
tippermad
Re: replacing fuel filter on a mk7
Postby v8dave » Sun May 17, 2015 12:43 am
There is no bleed screw on a mk7 filter housing.
You do exactly what many threads on here say.
On a warm engine
1) get a genuine ford filter.
2) fill it with fuel.
3) remove the old filter and promptly fit the new one - no stopping for a tea or a fag.
4) start the engine and keep the revs around 2,000 for a minute or two.
v8dave
Postby knobby1 » Sun May 17, 2015 2:36 am
Wot V8Dave said..!
Postby blue estate » Sun May 17, 2015 4:46 am
Works every time
blue estate
Postby bangertrack » Sun May 17, 2015 6:36 am
So what is the definitive method for the mk7 with the element and not the cannister, please?
bangertrack
Postby blue estate » Sun May 17, 2015 7:12 am
bangertrack wrote:So what is the definitive method for the mk7 with the element and not the cannister, please?
Start your own thread saying you've got a euro 5 engine as this one is for euro 4
and you've got a mk7.5 :wink:
blue estate
Postby walt1984 » Sun May 17, 2015 8:15 am
I did the same. Filled the bowl with diesel from a can, put the new element in and fastened it back on the filter housing. Started engine but i didnt know you was supposed to hold a few revs i left it ticking over. It stopped twice but restarted straight away. With these filters u can see how dirty they get mine was black!
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby v8dave » Sun May 17, 2015 11:29 am
To be fair OP didn't say if it is Euro 5 or other.
It's still fill the filter with diesel, then keep the revs up when restarting.
The theory behind doing it on a hot engine is that the air you've let in goes back to the tank rather than staying in the filter/pump loop.
v8dave
Postby tippermad » Sun May 17, 2015 1:54 pm
i got the fuel filter from a1 motor spares and it is the same as the old 1 so ill give it a go my mk6 ad a bleed screw on it but ill do what you have told me and thanks everyone who as educated me on this :D
tippermad
Postby bangertrack » Thu May 21, 2015 8:13 am
Changed mk7 filter element successfully thankyou. Messy business though!
bangertrack
Postby knobby1 » Thu May 21, 2015 9:22 am
bangertrack wrote:Changed mk7 filter element successfully thankyou. Messy business though!
Messy..? How so..?
I'm sure most of us can do them without spilling a drop. :wink:
Postby ake » Sat May 23, 2015 1:16 pm
Messy..? How so..?
Because he has a euro5 which has a filter assembly with removable element, not a canister type like euro 4
