Help, mk6 2.4 90psi snails pace no boost
Re: Help, mk6 2.4 90psi snails pace no boost
Postby matt171289 » Tue Jun 16, 2015 8:15 pm
Anyone?? lol
matt171289
Postby bazw » Thu Jun 18, 2015 11:55 am
If battery is dead as a dodo in a week the diode pack in the Alternator may have gone, this would allow a flow of current all the time it is turned off.
do you have a multi meter? if so check alt output as it may be reading high with a fault in it, and when disconnected and read across main connection you will see a DC amperage reading when all is switched off.
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby matt171289 » Wed Jun 24, 2015 8:11 pm
Hey, its reading 0.3amp, when ignitions is off.
matt171289
Postby bazw » Thu Jun 25, 2015 3:52 pm
sounds like a diode has gone then. I doubt anything else like the clock will pull anything like .3 of an amp.
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby matt171289 » Sun Jun 28, 2015 4:16 pm
Would the battery draining be linked to the van constantly slow? Like its in limp mode, all the time but taking ages to get to 40 (4 minute) abd max speed up hill 25mph?
matt171289
Postby matt171289 » Sun Jun 28, 2015 4:20 pm
Where would i find diode? In the ecu i suppose.
matt171289
Postby bazw » Sun Jun 28, 2015 4:29 pm
diode is in the alternator
2.4 duratorq 115 ps
A.R. 4.27
bazw
