Idiots guide to IDS
Re: Idiots guide to IDS
Postby Bryggi » Sun Jul 12, 2015 10:45 am
Yes I did. And y used your v86.04 update. Try the patch what was you files. I'd didn't run. But my v86 patch worked
Bryggi
Postby loot » Sun Jul 12, 2015 12:51 pm
Can you try it on another laptop?
07 350 170ps
Ids map here
loot
Postby Bryggi » Sun Jul 12, 2015 1:18 pm
I tried to find some laptop what to use
Bryggi
Postby loot » Sun Jul 12, 2015 2:07 pm
My dell mini 10 works perfect :-)
07 350 170ps
Ids map here
loot
Postby Bryggi » Sun Jul 12, 2015 6:57 pm
Tryed with acer one w7 and asus mini w7.. :(
Bryggi
Postby loot » Sun Jul 12, 2015 8:20 pm
You should be able to get it working3 without the vcm connected, it must be a software problem surely?
07 350 170ps
Ids map here
loot
Postby Bryggi » Mon Jul 13, 2015 4:25 am
Is there any change it is cable fault? Or where the program checks the voltage when reprogramming? Voltages are ok in dlc, and when i do the alternator test, there are readings normal too.
Bryggi
Postby loot » Mon Jul 13, 2015 7:58 am
Anything is possible but i had the 0v and i got it working after but as i say, i can't remember what i did :-(
07 350 170ps
Ids map here
loot
Postby knobby1 » Mon Jul 13, 2015 8:33 am
loot wrote:Anything is possible but i had the 0v and i got it working after but as i say, i can't remember what i did :-(
Have same issue here..I checked my cable and it's good, also popped the back off the VCM to see if there's something amiss, but nowt wrong, pin-out has continuity etc...I might just re-install everything and try again..
Strange really coz the live data shows all is good and 14.xx volts when engine is running etc... :?
Postby Bryggi » Mon Jul 13, 2015 8:50 am
When you install the patch, what is the correct tick when you choose the right clone? i ve selected the bottom one?
Bryggi
Postby loot » Mon Jul 13, 2015 9:06 am
Yes the bottom 1 :-)
07 350 170ps
Ids map here
loot
Postby loot » Mon Jul 13, 2015 9:10 am
I'm trying to think what resolved it but i know I've got a few vcm and the last 1 i had to go from Wi-Fi to cable because the Wi-Fi circuit in the vcm pood itself.
I just hope it isn't an internal vcm fault.
Although it has never happened on a new vcm from the off, and usually you get multiple disconnects before permanent failure.
So i am 99% it isn't the problem i had.
Knobby do you have the Wi-Fi version? Are you able to go to Wi-Fi rather than cable?
07 350 170ps
Ids map here
loot
Postby Bryggi » Mon Jul 13, 2015 10:28 am
I even havent try to connect with WiFi, because its allmost easyer to use Cable.
Bryggi
Postby wexican » Mon Jul 13, 2015 7:17 pm
Mine had a faulty USB cable, its worth a try, and its working on an Asus notebook W7
wexican
Postby knobby1 » Mon Jul 13, 2015 9:15 pm
loot wrote:Knobby do you have the Wi-Fi version? Are you able to go to Wi-Fi rather than cable?
No Wi-Fi unfortunately :( ....might give "wexican's" idea a go, never thought about the usb cable being duff.
