2004 85t260 immobaliser issue
Postby matthew*t260* » Sun Jul 12, 2015 5:12 pm
hi guys new member here , my pats light is flashing fast on key turn, was working fine then intermittant and now wont fire up or turn over, have ran a auto locksmith but they dont really want to know , can any one ive me detailed instructions on how to bypass it or can some one come and do it for me , van is parked on my drive and have the key please help i need the van for work,been searching and searching the internet on a guide, ive tryed to find member manandvan on ebay but no luck,please help :( :cry:
matthew*t260*
Re: 2004 85t260 immobaliser issue
Postby matthew*t260* » Sun Jul 12, 2015 7:12 pm
Ps I'm south cambridge,
matthew*t260*
Postby matthew*t260* » Mon Jul 13, 2015 9:14 am
No one gona help....
matthew*t260*
Postby loot » Mon Jul 13, 2015 11:17 am
You probably won't get any help on here to bypass any security system I'm afraid :-(
You may have a faulty key so it's a good idea to get fault codes read and get another key programmed and possibly look at the ignition switch, i presume they are the parts that get the most wear. :wink:
07 350 170ps
Ids map here
loot
Postby matthew*t260* » Mon Jul 13, 2015 11:43 am
Ive got a mechanic friend coming over after work but he doesn't have the ford IDS he has a couple of snap on computers , what would the chances of my key loosing it's code as the locksmith I spoke with said it wouldn't just drop the key code off the key, I'm at the point now that if I can't get it working by Friday Il be needing to rent or buy another van/flatbed for a big job I'm starting on Monday, cheers for the reply loot, ignition switch? Would that be the barrel? I've checked all plugs and connections and fuses I can see, I don't know where else to look :lol:
matthew*t260*
Postby Punto443 » Mon Jul 13, 2015 11:57 am
Transponders in the keys can become damaged by hard impacts and strong magnets, the reader ring around the ign barrel can become faulty and the wiring to pump and pcm can be chaffed or corroded leading to poor communication between components :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby matthew*t260* » Mon Jul 13, 2015 12:10 pm
What would cause it to go from working fine then working 1 every 10 turns of the key, the 1 every 50 turns then nothing, keys haven't been near any strong magnets, cant say if the keys been thrown/dropped, I've been digging around the back of feul pump, where the black plunger clip for the plug is, there's a water pipe and the bunch of wire is touching it, it still has its outer casing wrapped around the wire so I'm assuming there is no damage to the wires inside? pcm? That ecu ?
matthew*t260*
Postby matthew*t260* » Mon Jul 13, 2015 12:12 pm
Also the transponder ring if I unplug the wire and turn key it flashes instantly, with it plugged in the red light comes on then flashes so I'm assuming the transponder is working,
When I say assuming it means I'm guessing haha
matthew*t260*
Postby APH » Mon Jul 13, 2015 1:40 pm
On a 2004 van it's almost definately the Fuel pump EDC failing. Most common ways they fails is either cuts out and never starts again, or pats light starts to behave randomly and flash, sometimes preventing starting, sometimes not, getting gradually worse until It won't go at all.
As its a FWD van, I'd check the wiring to the pump for the chaffing/broken wire issue, as this only affected front wheel drives. But if all is ok, I'd almost put money on it being the pump. Have seen it so many times now :(
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby matthew*t260* » Mon Jul 13, 2015 2:31 pm
Cheers for the input aph, do you know if the pump itself would still work if the solenoid is rewired, I've been chatting to someone local and they say they can wire it up, obviously this would work out cheaper than replacement pump and edc and labour cost,
matthew*t260*
Postby matthew*t260* » Mon Jul 13, 2015 2:32 pm
I will have the wiring checked throughly first though, whats the best way to check visually or with a meter and trace wires back and check continuity
matthew*t260*
Postby matthew*t260* » Mon Jul 13, 2015 6:13 pm
It's been scanned with the big new snap on and has spat out codes
P0000 no code present
B2242 rear cargo door circuit open
B1330 right front door ajar circuit short to ground
Any ideas guys should I assume it's the key and find another locksmith?
matthew*t260*
Postby APH » Mon Jul 13, 2015 7:05 pm
matthew*t260* wrote:Cheers for the input aph, do you know if the pump itself would still work if the solenoid is rewired, I've been chatting to someone local and they say they can wire it up, obviously this would work out cheaper than replacement pump and edc and labour cost,
Solenoid can't be wired to anything directly to bypass the immobiliser as these pumps don't have a stop solenoid like the old di engines did. The pump has two solenoids that must operate exactly to specification, controlled by the EDC on the pump, otherwise the pump is useless. If the EDC has failed, it can be removed and sent for repair, or the pump can be replaced complete. However if it's a wiring issue going to the EDC then it can be repaired and all will be ok.
matthew*t260* wrote:I will have the wiring checked throughly first though, whats the best way to check visually or with a meter and trace wires back and check continuity
To test wiring properly you need a meter, and the how to I wrote on doing this is here: viewtopic.php?f=18&t=124587
matthew*t260* wrote:It's been scanned with the big new snap on and has spat out codes
Those codes would suggest the snap on was not compatible with your van, very few are as the transit does not follow and standard diagnostic protocol. You can always try a key reprogram by an auto locksmith if it's not too dear, but I'll be very surprised if it works tbh.
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby matthew*t260* » Mon Jul 13, 2015 7:34 pm
Thank you very much appreciate that, Il check the wiring tomorrow following your guide and update thread with my findings , I'm hoping I've got a broken wire somewhere but it's probably wishful thinking, she's on 170000 was otherwise running perfect
matthew*t260*
Postby APH » Mon Jul 13, 2015 7:46 pm
matthew*t260* wrote:Thank you very much appreciate that, Il check the wiring tomorrow following your guide and update thread with my findings , I'm hoping I've got a broken wire somewhere but it's probably wishful thinking, she's on 170000 was otherwise running perfect
That's ok mate, I'll keep everything crossed you find something, but at that mileage it could be wishful thinking unfortunately :( don't forget to give the loom a good bend and pull by the pump plug while testing just in case it's an intermittant break. Good luck,
Andy :D
(\__/)
(")_(")
this is bunny
APH
