drag racing 1/4mile times
Re: drag racing 1/4mile times
Postby limitedblack » Sat Jul 18, 2015 10:37 pm
Limpblack racing Lada 14.66 @ 95 mph :)
Plus I drive like that nearly everyday :) :)
Happy Easter
limitedblack
Postby mealic » Sat Jul 18, 2015 10:51 pm
Had a good week LB?
`04 2.3 petrol/LPG
mealic
Postby limitedblack » Sun Jul 19, 2015 7:28 pm
mealic wrote:Had a good week LB?
Yes thank you, just bobbing along again....
Happy Easter
limitedblack
Postby dieselhead123 » Mon Jul 20, 2015 10:29 pm
Well done to all who took part :D
AndyG, what happened to those lovely vids you took on your phone?
Postby MinorMatt » Tue Jul 21, 2015 9:33 am
Tell you what...
I'm going to make a (small) challenge. £100 reward for the first person who can get a 2.5di in a standard size (i.e. no chopping/channelling) roadgoing shell down the measured 1/4 miles in under 18s at North Weald or 17.5s elsewhere.
A few conditions though...
Only standard ford 2.5di engine parts may be used (i.e. anything which was factory fitted by Ford to any 2.5di transit. Standard parts can be modified/tweaked adjusted. (I.e. factory turbos, injection pumps and non marine injectors).
Transit axles must be used
Road legal tyres must be used.
Van must be roadworthy and driven to the event.
Passeenger seat(s) must be fitted
The time must be recorded at an official forum event with at least 4 witnesses
I think its doable, but will definately be a challenge
Postby g-man » Tue Jul 21, 2015 5:13 pm
moneys safe i reckon matt :wink: ..........unless wizards of nos lend a hand 8)
g-man
Postby MinorMatt » Tue Jul 21, 2015 9:22 pm
So long as its road legal...
I recon its possible without NOS. I have a couple of ideas which should knock some time off! I think its definately pissible.
Postby andypdq » Tue Jul 21, 2015 9:58 pm
Why 17.5 elsewhere? If it's "pissible", does that mean you have to be drunk whilst doing it? :P
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby mealic » Tue Jul 21, 2015 10:06 pm
On a different surface I presume.
`04 2.3 petrol/LPG
mealic
Postby andypdq » Tue Jul 21, 2015 10:38 pm
I reckon it is possible to do way better than that, but you'd need a huge amount of boost with adequate charge cooling, and massive overfueling, which would not be possible with any of the standard injectors. The subtle sport of tractor pulling is where to look if you want huge power from diesels, with diy backyard technology, achievable within a reasonable budget. 8)
https://www.youtube.com/watch?v=tU8uMa1RT-A
Tim has a way to go yet. :lol:
andypdq
Postby Luke » Tue Jul 21, 2015 10:54 pm
easly doable :mrgreen: - i reckon you should change it matt to under 17.5 @ NW :!: Tims only half a second off :D and with all that tramping................... :shock:
Postby MinorMatt » Wed Jul 22, 2015 9:15 am
Yes, so am I.
But Tim is disqualified due to non standard turbo, injectors and injection pump! That was in the 1st post.
North weald is slower than other surfaces as its not a dedicated drag strip. Others are smoother with a grippier start line
Postby g-man » Thu Jul 23, 2015 2:16 pm
but where low power trannys are concerned not much different,my best at weald is less than a tenth slower than shakey's
g-man
Postby limitedblack » Tue Jul 28, 2015 9:58 pm
Great, so the first person to make a high powered fuel gets £100. I have read the rules correctly?
Happy Easter
limitedblack
Postby limitedblack » Tue Jul 28, 2015 10:02 pm
Drat, looks like there are no road worthy Di's in the uk any more :(
Happy Easter
limitedblack
Return to Transit Talk
