Dead MK8
Dead MK8
Postby vehiclesystems » Thu Nov 26, 2015 4:26 pm
Hi Guys,
We have an issue with a 14 plate Transit 350 trend.
Whilst installing a tracking device at the driver fuse box area one of the wires was accidentally shorted. Either one of the small brown and yellow wires or a thicker purple with a red trace.
Since this has happened the ignition doesn't switch on, the key wont lock the vehicle, windows wont go down, cant lock the vehicle from inside.
We have been through the vehicle and checked every single fuse and everything appears to be okay and we are now stumped for ideas.
Can anyone help? The van is based in Washington Tyne and wear.
Thanks in advance.
Ash
August 2005 '55' Connect TDDI.
Bought with 19000 miles on in December 2007
Now has 160000 miles on (December 2010)
vehiclesystems
Re: Dead MK8
Postby Mike » Thu Nov 26, 2015 4:33 pm
Sound like you need a decent auto sparky to look at it, or as a last resort a Ford dealer.
Mike
Wind up merchant!
Re: Dead MK8
Postby vehiclesystems » Thu Nov 26, 2015 4:35 pm
I think you could be right Mike, its a customers vehicle and we need to get this back on the road for them, its all a bit of a mess. Ford dealer no doubt...
vehiclesystems
Re: Dead MK8
Postby Mike » Thu Nov 26, 2015 4:38 pm
Oops, good luck.
Mike
Wind up merchant!
Re: Dead MK8
Postby Altransit » Thu Nov 26, 2015 8:39 pm
Does it have a fusible link on the battery, or the front battery if there are two :?:
Re: Dead MK8
Postby moley551 » Fri Nov 27, 2015 10:25 am
On the custom there is some well hidden fuses under plastic covers behind the battery....inc the 64amp one for the seat aux power point
"Don't find fault, find a remedy"
H. Ford
moley551
