Crackling Dab radio
Crackling Dab radio
Postby Wesleymk8 » Mon Jul 14, 2014 9:21 pm
Well I've had my new transit for 3 weeks now and I've got a crackling coming through the speakers when using the DAB radio stations, it also jumps/skips every now and then too. None of the above happens when using the normal fm stations!! Has anyone come across this before and know what the fault might be?
Wesleymk8
Re: Crackling Dab radio
Postby CplSmudge » Thu Apr 14, 2016 7:09 am
I have this on our 350 H2L2 as well. I have tried to pin it down and so far I realise that the DAB seems to switch automatically to FM if it can't get the DAB signal.
I have tuned in a couple of stations on both FM and DAB and don't know if it is using the auto stored FM when it needs to or doing something else. I had a word with the chap in Allen Ford commercials in Swindon from whence my vehicle came and he said it shouldn't be doing that but then he doesn't seem to know a lot because I nearly ordered a Custom until I realised it had smaller width side loading doors and he said he didn't know!
I do the M4 into London regularly and sometimes the DAB switches and other times it doesn't. I'd say that was a problem but I am a driver not a mechanic / engineer so until I see it here I will not be convinced.
Chris
I ask the stupid questions so you don't have to
Every day is a learning day - my learning curve is vertical
CplSmudge
Postby joiner12007 » Fri Apr 15, 2016 7:55 am
My standard Fm radio does the same thing it seems to jump and skip also, it's due it's first service in a few weeks so I'm going to get them to check it out. Not good though.
joiner12007
