custom built chassis rules
Postby Guy88 » Thu Mar 31, 2016 8:30 pm
Does anyone know the regs for a replacment chassis that i build myself?
its on my MK1 thats been chopped about so making a full replacment may be an option i go for,
not worried about an IVA etc, but it has to keep the original reg number or an age related one
basically going to make the chassis out of box section and use bolt on MK5 chassis cab hangers for the axle, this will allow me to mount prop bearings etc to suit the v8 and also make it ready for air suspention
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: custom built chassis rules
Postby Wadey » Thu Mar 31, 2016 10:57 pm
You can re chassis a Land Rover but that's normally like for like
I believe if you modify it your suppose to re register it
It depends on how legit you wanna be as iv seen all sorts that been heavily modified so it should be re iva'd but there not so it's up to you ??
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby Guy88 » Thu Mar 31, 2016 11:06 pm
just read that Light goods vehicles under 3.5 but over 10 years old are IVA exempt :? :? :? :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ned » Thu Mar 31, 2016 11:18 pm
I thought it only had to be re registered if it is less than 40% of the original vehicle or was that q plates. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Guy88 » Fri Apr 01, 2016 9:20 am
Il give Dvla a call I think
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Wadey » Sat Apr 02, 2016 7:03 am
I'm sure there's still a test like an iva or sva it would need to go through and you would possibly loose the original plate I recon DVLA will tell you they will need to see it once it's done and will reel you if some junk that won't make sense !
If your gonna ring them do it first thing in the Morning iv always got straight through if iv not rang them early I'm normally on hold for ages and at £1 something a min it gets expensive !
Wadey
Postby captain hook » Sun Apr 24, 2016 6:10 pm
Just keep quiet about it all.
DVLA will make it impossible to register for the road and evrn if they do you will lose the rrg snd tsx exempt status!
Also will br impossible to get insurance for it...
Evrn trader's will knock it bsck.
captain hook
Postby stoney » Sun May 08, 2016 7:09 pm
Did you get anywhere with finding out the legality of this guy88?
I always thought the chassis was the identity of the vehicle and the rest was on a points system so as long as you had a certain amount of original components you could do what you like, but then what happens with all the professional chassis extensions or replacements like the alko ones bolted to boxer/relay/ducato's as I am sure they aren't inspected.
stoney
Postby Guy88 » Mon May 09, 2016 9:38 pm
stoney wrote:Did you get anywhere with finding out the legality of this guy88?
No IVA needed on light commercials over 10 years old,
the way i see it im not modifying the chassis, im restoring it, thats what il tell them if i get stopped
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ned » Mon May 09, 2016 10:41 pm
Most of the people who will see the chassis probably don't know what a mk1 chassis looks like anyway. N
ned
