HEATER WILL NOT GET WARM ALSO TOO MUCH PRESSURE IN COOLANT
Postby smalley » Mon May 14, 2007 11:10 pm
I HAVE JUST BOUGHT 02 TRANSIT AND ITS GREAT BUT HEATER WILL NOT GET WARM IS COLD AND ALSO THERE IS A LOT OF PRESSURE IN COOLANT
smalley
Postby MrMPuk » Mon May 14, 2007 11:12 pm
Sounds like duff water pump, also typing in capitals is shouting!
Postby smalley » Mon May 14, 2007 11:14 pm
:D Soz im new to this also when the van has stopped the coolant bottle is makin a hissing noise
smalley
Postby AndyG » Mon May 14, 2007 11:19 pm
As MrMPuk says :!: sounds like your water pump :!: Common prob :( impeller slipping on its spindle :!:
Postby MrMPuk » Mon May 14, 2007 11:20 pm
Temp only goes third of way
Postby smalley » Mon May 14, 2007 11:25 pm
Thanks for that but mine i cant get the van to get hot i can run the van and temp only goes bout third of the way and will not go any higher
smalley
Postby MrMPuk » Mon May 14, 2007 11:28 pm
Well get it checked because I bet that is correct.
Could it be a thermastat
Postby smalley » Mon May 14, 2007 11:30 pm
MrMPuk wrote:Well get it checked because I bet that is correct.
cud it be the thermastat can i do anything to find out wot is causing it
smalley
Postby MrMPuk » Mon May 14, 2007 11:32 pm
The pressure is there because it is getting too hot, the temp isn't going up because the water isn't circulating. As I said get it checked.
