Mk 4&5 compatible high output Alternators
Postby nasifkhan » Mon Jun 13, 2016 4:27 pm
HI
Currently I have the standard 95A alternator but I was looking for something bigger. There are some aftermarket ones that give output at 120A but they are pricey.
What other vehicle/brand alternators are compatible with mk4&5
nasifkhan
Re: Mk 4&5 compatible high output Alternators
Postby MinorMatt » Mon Jun 13, 2016 4:54 pm
None as far as I know (because of the vac pump on the back)
Postby ceurieusneus » Mon Jun 13, 2016 5:29 pm
Minormatt is right, couldn't find anything bigger neither.
Maybe better to, because on the forum there are problems registered with the bolts who have to hold the alternator. 8)
More power full alternator... bigger forces on those bolts. :wink:
More problems that could arrive :mrgreen:
I upgraded my MK3 with a 95A alternator, hope for minor problems, I will not go to a foreign country without spare bolts 8)
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby CamperVanBeethoven » Mon Jun 13, 2016 5:56 pm
No idea how or where you get the appropriate bits and bobs (including longer belt), but apparently some ambulances had a 'dual alternator' arrangement. That's one possibility ...
CamperVanBeethoven
Postby nasifkhan » Mon Jun 13, 2016 5:58 pm
Thanks for the replies.
I have read about dual alternators but that's something I wanted to stay away from.
From memory...it was an extra pull with longer belt and attaching the other alternator somewhere and the wiring it.
But that's something I didn't really want.
nasifkhan
Postby F111ORY » Mon Jun 13, 2016 7:28 pm
Hi, I have second alternator on my diesel camper. It is fitted under the exhaust manifold and driven by the power steering belt.
F111ORY
Postby ceurieusneus » Mon Jun 13, 2016 8:41 pm
F111ORY wrote:Hi, I have second alternator on my diesel camper. It is fitted under the exhaust manifold and driven by the power steering belt.
Please tell us more about it
Where did you buy the components
Where came the second alternator off? Type off alternator?
How is it bolt on, how is it tensioned?
How heavy is the second alternator?
Does they charge the same battery or separated battery's banks?
Pictures please???
ceurieusneus
Postby Altransit » Mon Jun 13, 2016 9:36 pm
nasifkhan wrote:HI
I have to ask; why do you need bigger than a 95 amp alternator :?:
Postby nasifkhan » Mon Jun 13, 2016 10:58 pm
It's an ice cream van. I have a battery bank that needs charging at a high rate due to the equipment on board.
nasifkhan
Postby F111ORY » Mon Jun 13, 2016 11:45 pm
Pictures please???
viewtopic.php?f=18&t=139218&p=1156785#p1156785
viewtopic.php?f=4&t=139218&p=1156973&hilit=Second+Alternator#p1156973
Hi, I think the second alternator came from a scrap Montego. It charges a second 95 amp battery for the camper internals and is tensioned by moving the power steering pump. John Deere forage harvesters have 2 or 3 alternators all connected to the same battery so no problems in having more than one alternator on a vehicle.
F111ORY
Postby F111ORY » Mon Jun 13, 2016 11:49 pm
F111ORY
Postby Aardvark » Tue Jun 14, 2016 10:33 am
If you already have the 95amp unit in place then I suggest you take a look at http://www.adverc.co.uk/products/ site. One of their charge controllers could do the trick. It takes over from the built-in regulator to allow the alternator to go flat out until the battery us fully charged, rather than tapering off the charge rate like the standard regulation. They are usually fitted to public service vehicles, etc. that do a lot of starting and short trips.
Learning to love rust.........
Aardvark
Postby nasifkhan » Wed Jun 15, 2016 5:42 pm
Had a look on their website but couldn't find anything. I'll give them a call
nasifkhan
Postby blizard » Wed Jun 15, 2016 8:09 pm
You could install a Sterling Alternator Regulator. http://sterling-power.com/collections/a ... reg-d-pdar
Your alternator will act like pro charger
Transit MK3 1987
Chausson Motorhome
Engine 2.5TD of 2000 (last production year of the DI, I'm told)
Gearbox MT75
blizard
Postby 97transit2.5D » Wed May 19, 2021 1:08 pm
hi i have a 1996 bana smiley 2.5di van non turbo
the alternator is it 95A,,,,yes mine has brake servo pump on back of alt...and is it 12V ??? or 14V spec???
97transit2.5D
