Back with a mk7 this time!
Postby dirtydog » Sun Aug 14, 2016 9:18 pm
Thought I'd start a little progress thread for my new to me mk7.
So a few details first, 115 350 rwd, lwb, med roof, has a few toys as standard including heated screen, leccy mirrors, front fog lights, auto lights and auto wipers 8)
Previous owner was a builder and it was a bit of a mess when I bought it, very dirty but it runs well
As you can see its filthy! And it smells really bad of diesel in the back.
Got a few plans and ideas for it but first up is cleaning it inside and out so I started with the inside
dirtydog
Re: Back with a mk7 this time!
Postby blue estate » Sun Aug 14, 2016 9:25 pm
Did he mix he's muck inside the back :shock: I've seen cleaner concreate mixer drums :lol: :lol:
blue estate
Postby Punto443 » Sun Aug 14, 2016 9:25 pm
Nice motor :D
Looks like a bit of a project?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby dirtydog » Sun Aug 14, 2016 9:38 pm
I stripped all the ply lining out of the back and got to cleaning it up
That took all afternoon. The dirt was about 15mm thick up near the bukhead where they stopped short with the ply on the floor :shock:
Swept out a lot of dirt and sand.
The floor is mostly ok, worst bit is by the side door and the side door step has a hole in it and it's full of dirt underneath, so I guess I'll be replacing the step :lol:
dirtydog
Postby boltondigger » Sun Aug 14, 2016 9:41 pm
That ones been loved :) :) :)
will be ok with some TLC
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby dirtydog » Sun Aug 14, 2016 9:43 pm
blue estate wrote:Did he mix he's muck inside the back :shock: I've seen cleaner concreate mixer drums :lol: :lol:
God knows what he did in the back of there, whatever it was it didn't involve cleaning of any sort :lol:
dirtydog
Postby dirtydog » Sun Aug 14, 2016 9:45 pm
Punto443 wrote:Nice motor :D
Yeah it will be a bit of a project for me, might keep me out of trouble :wink:
boltondigger wrote:That ones been loved :) :) :)
Giving it some TLC is the plan
dirtydog
Postby blue estate » Sun Aug 14, 2016 9:51 pm
Give dieselhead123 Tim a shout for the step panel as it's same as mk6
You've increased the pay load by half a ton now
blue estate
Postby dirtydog » Sun Aug 14, 2016 10:06 pm
I have a fair sized list of things that need to be done and things that I want to do to it
First up is clean up the floor (couldn't find my wire brush today) and paint it, then ply line it and build some racking in the back so I can keep it tidy then I'll start on the cab and then the outside.
Other plans include in no particular order, side bars, a handful of marker lights, sport style front bumper, reversing camera, wind deflectors, maybe some heated seats, alloy wheels, roof rack/bars, led interior lighting, etc etc :lol: 8)
Edit: and a trip to vantuner for an egr delete
dirtydog
Postby ned » Sun Aug 14, 2016 10:48 pm
If you plan on putting marker lights on the sides do it before you build the racking as its easier to wire up unlike me who had to struggle in a 6 inch gap :D you can get all different colours of 12v 6 led marker lights on ebay £10 for 10 lights I got a mixed pack of 30 (10 clear, 10 red and 10 amber) for £30 and 10 amber for another £10 all running on the side light circuit, before you choose your colour make sure you check the legal legislation for vehicle lights (you don't want your botty polished by the Sweeny).
Floor doesn't look too bad what are the inner arches like. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dirtydog » Sun Aug 14, 2016 11:09 pm
Side markers I was just going to go with some in the side bars.
Yeah the floor isn't bad at all just a bit of surface rust except the step. Inner arches are ok, passenger side one is a bit battered where it had no boxing but other than that they're good
dirtydog
Postby dirtydog » Tue Aug 16, 2016 11:26 pm
Got a bit more done today, started with removing the glue residue from the sign writing but it's tedious and I got bored after 1 side :oops: :lol:
So I got to work on the rear floor
Started with this
After a going over with a wire wheel and drill
Treated with Jenolite
And primed
Should get some more of the floor done tomorrow. Once I've treated the rust I'll probably just hammerite it or rustoleum on it
dirtydog
Postby loot » Thu Aug 25, 2016 7:55 pm
It's promising to be a nice van this 8)
07 350 170ps
Ids map here
loot
Postby dirtydog » Thu Aug 25, 2016 8:53 pm
Yep it certainly has promise, the only thing that may hold it back is me :oops: :lol:
All the sticker glue residue is now gone, have picked up some Farecla stuff from the local halfrauds and gave it a try on a little bit and it works well removing a lot of the small scratches and the sticker shadowing. Although I think they tried to remove the signewriting with a brick as there's quite a lot of deep scratches :x
Done a little bit more to the floor but nothing worth taking a picture of!
Fuel cap flap got its first coat of paint tonight as well
dirtydog
Postby dirtydog » Wed Aug 31, 2016 10:20 pm
Managed to get the rusted bolts on the bulk head cleaned up enough to get them out with my little dewalt Impact driver just need to decide whether it's worth cleaning it up or just replacing with a better one. It's got a fair bit of rust on it, escpeially at the bottom and also a 10cm X 10cm hole cut in it :?
dirtydog
