What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby CamperVanBeethoven » Fri Sep 23, 2016 11:11 pm
pelmetman wrote:Painted the tow bar today 8) .......and topped up the water tank and emptied the bog again :mrgreen: .....
National Shite Day ;)
CamperVanBeethoven
Postby Aardvark » Sat Sep 24, 2016 10:11 am
Replaced cam belt and tensioner, oil & filter change, fuel & air filter change, cleaned the battery terminal connections, and popped a new bolt into the steering pump that had been missing for a few years. Only whacked my bloody head twice on that sharp corner of the bonnet.
Learning to love rust.........
Aardvark
Postby angusp » Sat Sep 24, 2016 1:55 pm
That bonnet corner is a demon and I never seem to learn to avoid it!
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby angusp » Sun Sep 25, 2016 9:10 pm
Took the expansion tank container for the coolant off to give it a good clean - had a nice coating of sludge on the inside. Couldn't get anything inside so asked wife what to do - rice and hot water- worked a treat.
angusp
Postby davew2 » Mon Sep 26, 2016 8:00 pm
angusp wrote:Took the expansion tank container for the coolant off to give it a good clean - had a nice coating of sludge on the inside. Couldn't get anything inside so asked wife what to do - rice and hot water- worked a treat.
mate of mine swears by kettle descaler :wink:
If it ain't got leaf springs it in't a commercial
davew2
Postby gotgcoalman » Mon Sep 26, 2016 8:17 pm
Got recovered by the RAC :(
No clutch :D
What could it be?
Adjusted it up and no pedal,
Clue is "it's not a snapped cable"
I'm also thinking it can be done "in situ" without removing the gear box although it isn't going to look pretty :D
Too bloody quiet :shock:
gotgcoalman
Postby MinorMatt » Mon Sep 26, 2016 8:29 pm
Its a snapped/cracked fork
Postby gotgcoalman » Mon Sep 26, 2016 8:38 pm
MinorMatt wrote:Its a snapped/cracked fork
Bingo.
MinorMatt wins first prize.
What possesed Ford to use such a flimsy arm :?:
I'll have a look for one of the "older" more substantial one's.
Will have to rely on Mr mig or Mr arc to get me back on the road tomorrow though
:lol:
gotgcoalman
Postby gotgcoalman » Tue Sep 27, 2016 12:08 pm
Mobile again :D
The ultimate bodge job :roll:
gotgcoalman
Postby CamperVanBeethoven » Tue Sep 27, 2016 10:36 pm
Impressive :)
I'd be tempted to just seam weld the crack and leave it like that ;)
DIsclaimer: OK I can't actually weld, so I dunno how easy or hard that would be in situ ...
CamperVanBeethoven
Postby gotgcoalman » Wed Sep 28, 2016 3:15 pm
Did 150 mile round trip today with deliveries.
Crapping it at EVERY gear change incase the frankenstein clutch arm gave way.
It didn't :D
gotgcoalman
Postby MinorMatt » Wed Sep 28, 2016 4:30 pm
You can change gear without using the clutch...
Postby Altransit » Wed Sep 28, 2016 4:54 pm
gotgcoalman wrote:Did 150 mile round trip today with deliveries.
It didn't :D
Remember that a job is only a bodge if it doesn't work, or doesn't work for long :P :mrgreen: :lol:
Postby Aardvark » Wed Sep 28, 2016 5:57 pm
MinorMatt wrote:You can change gear without using the clutch...
I've done that in the past but its a bugger in slow stop & go traffic. :?
Aardvark
Postby gotgcoalman » Wed Sep 28, 2016 6:03 pm
Yep done it a couple of times when I had a clear run back home.
Although it's a bit difficult going through a town centre fully loaded when every other motorist either doesn't see you
or assumes they have right of way regardless :(
It didn't :D
It's many times stronger than the original design :D
I was expecting it to go further up the "ford part"
On a plus note the random judder has gone when pulling away now :D
gotgcoalman
