Injector seal leaking
Postby Paul.G » Sun Oct 23, 2016 5:28 pm
I have a 2007 2.2 Tdci 110/260 fwd Transit.
I did a search and cannot find any instruction video on how to change seals/injectors, if anyone can give me a link to one that would be appreciated.
I had the Airfilter box out this morning and noticed the rocker cover is covered in oil/diesel, started the engine and see slight seapage around pot 1+3 injectors, is this the injector knackered or can I change seals and the problem be gone?
Any help appreciated
Paul
Paul.G
Re: Injector seal leaking
Postby wronghole » Sun Oct 23, 2016 9:12 pm
Replacing clamps bolts and copper washers would be a good first move. Also a good idea to ream out injector seats to ensure a tight seal. NB use ford only parts :D . plenty on this forum about this. :D
wronghole
Postby Altransit » Sun Oct 23, 2016 11:40 pm
One pair of injectors are held down by a single clamp with just one long skinny bolt, which is probably why they are prone to coming undone and leaking.
Remove the bolt, take off the clamp, remove the wiring connector, fuel inlet and leak off pipes, and the injectors will just pull out.
If the sealing washer doesn't come out with the injector, you'll need to fish around in the bottom of the aperture to remove it. If it looks in good condition, you'll get away with just replacing it with a new one, if not, you'll need to gently ream out the base of the aperture before replacing the washer. Do this for both injectors of the clamped pair.
Refit the injectors, and the clamp, using a brand new bolt, do NOT re-use the old one, make sure you clamp it down tight, but do not overtighten. Replace connector, diesel pipes, and anything else you've removed, and the job is done :)
I just did the one pair on mine, but I have the parts ready to do the other pair if either of them start leaking
Postby Paul.G » Mon Oct 24, 2016 7:04 am
Thanks for the info fellas, what do I use to ream, is there a special tool?
Paul.G
Postby Altransit » Mon Oct 24, 2016 8:21 am
Yes, I just bought a cheap set from ebay, which included the correct size for this engine
E.G.http://www.ebay.co.uk/itm/UK-Profession ... Sw0e9UyfMI
Postby v8dave » Mon Oct 24, 2016 1:07 pm
Change the little green orings on the leakoff pipe as well. They are easily damaged and usually leak air in rather than letting diesel out, the resulting air leak will give you starting problems. Lubricate them with grease or oil when fitting.
v8dave
Postby Paul.G » Tue Oct 25, 2016 7:16 am
Thanks for the link, do I need to bleed the system after removing and replacing the injectors?
Paul.G
Postby Altransit » Tue Oct 25, 2016 8:26 am
I've done this a few times on a Focus TDCi, and once on my Transit TDCi, and never needed to bleed the system afterwards :wink:
Postby knobby1 » Tue Oct 25, 2016 10:29 pm
Paul.G wrote:Thanks for the link, do I need to bleed the system after removing and replacing the injectors?
As Altransit says...no need to bleed a common rail system....it's self bleeding.
Postby Paul.G » Tue Oct 25, 2016 10:46 pm
Thanks for all the help chaps, it was dark when I got home tonight so hope to get a chance to have a closer look tomorrow, living in Shetland we dont have as many suppliers as on the mainland, is there a part number anyone has for a seal kit please?
Paul.G
Postby Altransit » Wed Oct 26, 2016 12:45 am
Take your pick:-
eBay listings
But you'll need to order the bolts from a Ford dealer, part No.1673999 (don't buy their copper washers though)
Postby Paul.G » Tue Nov 15, 2016 8:27 am
I went to the only Ford dealer in Shetland and the seals are £13+vat each so went to the only Motorist shop on the Island and they wanted £37+vat each, I got home and looked on ebay and there is a kit with 4xblack seals, 4xcopper washers and 4xgreen leakoff O-rings for £38ish, anyone know if the ebay kits are good quality?
Paul.G
Postby t0m541 » Tue Nov 15, 2016 9:07 am
I bought this kit from eBay and they seem perfectly ok
http://www.ebay.co.uk/itm/282165749084? ... EBIDX%3AIT
£28 with free p+p
15 plate Custom 2.2 Trend eTech in black, it's so good to be back in a Transit...
t0m541
Postby Hovervan » Thu Nov 17, 2016 8:48 am
You can get the copper washers at every authorised Delphi workshop or reseller for around 2€ each. The seals in the cam cover are avaliable on aftermarket; my were from Corteco if I remember it correctly...
Sometimes I think the Ford parts man has a giant dice behind his counter, with about 20 sides from 10 to 1000 €, and whenever you need a part he just throws it... :mrgreen:
Hovervan
Postby Paul.G » Sat Nov 19, 2016 9:40 pm
Tom that looks like the kit I saw but think the black seals had a tab at either side, the van is my everyday transport and not sure which are right for my engine till I start taking everything apart.
I couldn't hold back laughing when they told me the prices per seal :)
I think I have coolant leaking into the oil now too as the oil filler cap has creamy sludge in it and it is looseing coolant.
Paul.G
