Cam Carrier/Head 2.4 RWD 2006 WANTED
Postby RayTrans » Wed Feb 08, 2017 9:56 pm
Hi all
I am looking for a Cam Carrier, Cams or a full head for my 2006 2.4 Puma RWD 115bhp like the one in the photo
Cheers 8) 8)
Ray
MK6 Transit High Roof RWD 115 Bhp Twin Sliding doors.
RayTrans
Re: Cam Carrier/Head 2.4 RWD 2006 WANTED
Postby knobby1 » Wed Feb 08, 2017 10:07 pm
Mk6 or Mk7.....2006 was the "change-over" year.
The pick looks like it may be a Mk6...??
Postby karl » Wed Feb 08, 2017 10:36 pm
knobby1 wrote:Mk6 or Mk7.....2006 was the "change-over" year.
Yes it's 2.4 duratorqe head
karl
Tranny Lover!!!
Postby karl » Wed Feb 08, 2017 10:37 pm
I have a complete engine with pump and gear box £600
Manchester area can put it on a pallet for courier at you cost
karl
Tranny Lover!!!
Postby RayTrans » Wed Feb 08, 2017 10:46 pm
karl wrote:I have a complete engine with pump and gear box £600
Hi Karl can you PM me your contact number. Cheers
Cheers 8) 8)
Ray
RayTrans
Postby RayTrans » Wed Feb 08, 2017 10:52 pm
This the reason I need a Cam Carrier/Head for my Transit
Cheers 8) 8)
Ray
RayTrans
Postby knobby1 » Wed Feb 08, 2017 11:23 pm
Both Mk6 & Mk7 RWD's are 2.4 Duratorq engines.. :roll:
Your last pic certainly looks like Mk6 injectors in there..!
Postby RayTrans » Wed Feb 08, 2017 11:30 pm
Hi Lord Knobrot yes you are correct it is a 2.4 Rwb 115 Mk 6 Transit.
Is there much difference between the Mk 6 & Mk 7 2.4 engines
Cheers 8) 8)
Ray
RayTrans
Postby knobby1 » Wed Feb 08, 2017 11:45 pm
RayTrans wrote:Hi Lord Knobrot yes you are correct it is a 2.4 Rwb 115 Mk 6 Transit.
Is there much difference between the Mk 6 & Mk 7 2.4 engines Cheers
The basic engines are quite similar, although they do have their differences, the Mk6 is generally TDDi, (there is an evil TDCi version though)... the Mk7's are all TDCi (Common Rail)...and have a lot more electrickery on them.
Even the Mk7 2.4 engines differ between models, the 140 is quite different to the lower power jobbies...they have two oil filters and a VNT turbo with electronic actuator... just to mention a couple.
Postby RayTrans » Wed Feb 08, 2017 11:56 pm
Right, the reason I ask is on Etis my van is down as a 2.4 TDCI PUMA, but to me it is a TDDI as there is no common rail, all pipes lead to the fuel pump, so I keep asking myself was the engine allready changed before I bought it. There is a 5:88 diff in it, so it is screaming at 3000 PM doing only 55 mph so even do it has only 174,000 miles on the clock it has been a hard slog for the engine. Cheers for the help
Cheers 8) 8)
Ray
RayTrans
Postby knobby1 » Thu Feb 09, 2017 12:59 am
RayTrans wrote:Right, the reason I ask is on Etis my van is down as a 2.4 TDCI PUMA, but to me it is a TDDI as there is no common rail, all pipes lead to the fuel pump, so I keep asking myself was the engine allready changed before I bought it. There is a 5:88 diff in it, so it is screaming at 3000 PM doing only 55 mph so even do it has only 174,000 miles on the clock it has been a hard slog for the engine. Cheers for the help
Yeah...Etis did have a few issues with the info on them for some models...yours is obviously one of them..!
Postby ake » Thu Feb 09, 2017 7:26 am
The 115ps 2.4 was incorrectly listed on etis, it's a TDDi.
Postby RayTrans » Thu Feb 09, 2017 1:46 pm
ake wrote:The 115ps 2.4 was incorrectly listed on etis, it's a TDDi.
Gentlemen thank you for clearing up that problem for me as now I know why parts people would look at me like I had 2 heads when I would be asking for 2.4 Tdci parts. Again thanks for the help it is massive. Cheers.
Cheers 8) 8)
Ray
RayTrans
Postby ned » Thu Feb 09, 2017 6:35 pm
Wasn't the 135ps 2.4 mk6 a tdci? N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
