Finally my new to me mk7
Postby Tompoole » Sun Feb 19, 2017 4:46 pm
Took a while to get another but finally chose a mk 7 125 trend i25k miles instead of a custom....
Will use it for work but plan to make it into a day van as well, not sure on what colour but looks same a mail van.
Tompoole
Re: Finally my new to me mk7
Postby rimotu66 » Sun Feb 19, 2017 4:50 pm
Looks straight does that, is that 125k or 25k? What made you go for a 7 instead of a custom?
2007 SWB 110PS GLX Mk7
rimotu66
Postby Tompoole » Sun Feb 19, 2017 4:51 pm
25k . Went for mk7 for size and ££££ cheaper lol
Tompoole
Postby robbie.cee » Sun Feb 19, 2017 5:10 pm
Good shout. Least the doors wont fall off it !!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby smokeytransit » Sun Feb 19, 2017 5:20 pm
Nice van 8) one word of advice I would give u is to secure your wheel trims (hub caps) as they are known to be stolen. :shock:
Ford, all the power beyond the world.
Mk6 transit 85 t260
smokeytransit
Postby Tompoole » Sun Feb 19, 2017 5:30 pm
What's with doors falling off customs?
Tompoole
Postby ned » Sun Feb 19, 2017 6:07 pm
Tompoole wrote:What's with doors falling off customs?
:lol: There check straps are made of chocolate :lol:
Nice looking van you've got there 8) its not camera shy is it :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Kristianskaffe » Sun Feb 19, 2017 8:16 pm
smokeytransit wrote:Nice van 8) one word of advice I would give u is to secure your wheel trims (hub caps) as they are known to be stolen. :shock:
Secure them how? :)
I just received 4 brand new for mine :)
http://www.kristianskaffe.dk
Follow me here and see what I´m fooling around with :D
https://www.instagram.com/kristianskaffe.dk/
2006 Transit undergoing makeover and refurb :D
Kristianskaffe
Postby smokeytransit » Sun Feb 19, 2017 9:20 pm
Secure them how? :)
What I did to secure mine involved getting some steel fence wire and putting it through the steel ring on the rear of the wheel trim and then through the steel wheel and twisting it to get the wire taught. In order to do this you will have to get under the van also put some cable ties on the outside as usual so if they do cut them and try to remove them they might just give up. This is the best solution I can think of at the end off the day if they want them they will get them hope this helps.
Mk6 transit 85 t260
smokeytransit
Postby Kristianskaffe » Sun Feb 19, 2017 9:22 pm
Seems easy enough. Good idea, even though I never had mine stolen
Kristianskaffe
