paul2012 wrote:Transit mk6 2.0 TDCI 125ps & 2.4 TDCI 135ps injectors do have 16 digit correction no's - shown below & yes they do require to be programmed to PCM.![]()
It's TDDI's that don't
I'll keep my gob closed from now on..!
vanduara37 wrote:
Anyone got a solution for this ? made an ar*e of install vcm2 v100.01
spudd wrote:Advice please. I just bought this,http://www.ebay.co.uk/itm/232261351228? ... EBIDX%3AIT.
Should I buy this ,http://www.ebay.co.uk/itm/321988116953?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Or this,http://www.ebay.co.uk/itm/122389844610? ... EBIDX%3AIT
Or do you recommend something else.
loot wrote:Does anyone know if it is possible to turn off a selected injector in ids? Also while driving?
(Solved)Ford VCM II module programming unavailable
Posted on September 28 2014 by diagkey.com in vcm 2
Just got my VCM 2 (clone) and desperate to try it out. Was disappointed because when I opted for module programming got the message “option unavailable” Contacted the seller xcardiag.com e-Shop for solution. And they help me solved. If you also have the same problem, the following solution may be helpful.
Solutions:
There were 2 discs that came with the vcm, 1 disk will be full ids v81 + c81 installation on dvd, the other disk will be ids v86 and patch only on a cd.
Install v86 + patch from cd then install v81 calibrations (installer) from dvd. As for installing patch, you have to open the patch file and run do not try to work it before installing the patch.
After this you need another patch called Ford extending program which you simply run and it extends the module programming function.
Then install v81 calibrations (installer) from dvd
