Loots Red custom
Re: FOR SALE: Sport body kit
Postby bigjohnthomas » Sat Apr 29, 2017 7:34 pm
:lol: no ive not done that bit of a job yet :oops:
and at a show tomorrow but i have penciled it in for early may :P
ish :lol:
bigjohnthomas
Postby loot » Sat Apr 29, 2017 7:44 pm
Pish, I'll have my kit fitted and automatic electric windows roll up module that motorworld said doesn't exist and that i need to go and do some homework, fitted by lunch time 8)
07 350 170ps
Ids map here
loot
Re: Sold
Postby bigjohnthomas » Sat Apr 29, 2017 7:54 pm
Yeah but...but...but.,,, you've not got dragon knickers to contend with
bigjohnthomas
Re: Sold
Postby loot » Sat Apr 29, 2017 7:56 pm
Joking aren't you, I'm going on a 10 mile run tomorrow with my mrs, she'll have worked a 12hr night shift and i have 2 sore toes. Can go either way but I'll use the art of persuasion to get the job done :o
So the big question remains, have you done it yet? :P
07 350 170ps
Ids map here
loot
Re: Sold
Postby bigjohnthomas » Sat Apr 29, 2017 8:30 pm
Perhaps if you were a lazy fat b*stard like me you would be more understanding :P
bigjohnthomas
Re: Sold
Postby loot » Sat Apr 29, 2017 8:41 pm
bigjohnthomas wrote:Perhaps if you were a lazy fat b*stard like me you would be more understanding :P
Oh but I'm am fluent in the arts, so much so that i failed the Jedi training test owing to can't be arsed to wave my hand and say, these aren't the droids you are looking for :? It was hmm ah fokking take them, they're mk7 tramp droids anyway :lol:
07 350 170ps
Ids map here
loot
Re: Loots Red custom
Postby loot » Sat Apr 29, 2017 10:34 pm
Better than i could do.
:D
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Sat Apr 29, 2017 10:50 pm
bargain 8) get the glue out :P
bigjohnthomas
Postby loot » Sat Apr 29, 2017 11:16 pm
:P
07 350 170ps
Ids map here
loot
Postby ned » Sun Apr 30, 2017 2:50 pm
Ooooow shiney 8)
Is it on yet, is it on yet, is it on yet :lol:
What's the pink bit? Have you fitted it yet. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sun Apr 30, 2017 3:04 pm
Not yet, day off :P
Pink bit is a cup, we put liquid in it, holds very well :lol:
07 350 170ps
Ids map here
loot
Postby ned » Sun Apr 30, 2017 3:13 pm
:lol: A cup, thought it was part of the kit :roll: D'oh. N
ned
Postby loot » Sun Apr 30, 2017 3:15 pm
:lol:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Thu May 04, 2017 11:52 am
loot wrote:You need the capacitor it builds up power and discharges it, it is only 16v so it is very gentle, not like those 1.21gigawatt ones you used to bridge to blow them up 4 a laff :shock:
I fitted the 2 ceramic resistors but you don't need them, you can't use a resistor but on the Ford mini relay there is a resistor which will station the capacitor to 0v but it will do that through the relay coil anyway.
The capacitor world both directions so it is able to recharge both ways, i thought it was like a diode and reversing the power wouldn't work, it does and it warms up (the system is never active long enough to warm it up tho, in fact it isn't on long enough to give the cap full charge and that means it doesn't hold as long as it did on the bench, but it does latch long enough to overcome the wake up for unlocking)
Anyway if you want to copy my setup that's fine.
So you need about 18 inches of cable, i had a length already of 2 core 1.5mm/1.0mm whatever the kids these days use :D
Relay, standard 1 but i used the Ford mini type.
4700uf 16v capacitor, found mine in a car radio along with the ceramic ballast resistors.
1 or 2 ballast resistors just because i had them and felt they might add some sense of added safety to it :lol: 5watt 0.3ohm (no reason for that except they were in with the capacitor so I'll trust Visteon maths ppl.
Door actuator connector unplugs nicely and you can cut wire pin3 15mm from the connector then strip the 2 part wires and join them to each wire you have for the relay coil that has the cap etc on it. It is bidirectional and a solid wire when cut becomes positive and negative (provided you have a load fitted otherwise it becomes a dead short ie removing a light bulb and linking both terminals. In this case there is already a load (door actuator) so connect there.
Male side shown.
Then the other 2 wires connected to the mirror switch pin 4 and 8.
I used heat shrink etc to clean up and gaffer tape on the actuator the same as for did
Which ones pin 3 on the actuator ? Tried 3 and 6 the one and its not bloody working have to put it back together for now big job on
bigjohnthomas
Postby bigjohnthomas » Thu May 04, 2017 12:28 pm
Got it now 8)
I love you loot :P
bigjohnthomas
