andz327 wrote:Digrizrat wrote:I think my inside driver's door handle isn't original. Cleaned the dash and all hard surfaces with sprayandwipe yesterday, and the white writing on the lock button just wiped right off!
Otherwise it looks fine so I can't really fault the Chinese part copiers I guess, but they need to work on their print skills.
I know it's hard to remember where the lock is these vans, had to climb out the window the other day cause I couldn't find the lock button...... Silly me if I had switched engine off I could have pressed the key button.....![]()
Sent from my D6603 using Tapatalk
Tango330 wrote:I left mine in pieces in the rush to get down the fire station![]()
Had to put it all away when I got back in the dark.
Rumble bee wrote:Today I mostly pressed the air con button![]()
nedforceone wrote:Rumble bee wrote:Today I mostly pressed the air con button![]()
Nice hornsN
Rumble bee wrote:nedforceone wrote:Rumble bee wrote:Today I mostly pressed the air con button![]()
Nice hornsN
nedforceone wrote:They make my Dixie horn look smallN
richgold wrote:
Christ on a bike Chris!
I havent seen a pic of your van for a quite a while!
You've been busy havent you?
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
