BCM problem / no high beam / no taillights
Postby Hovervan » Fri Jun 30, 2017 9:51 am
I recently swapped my BCM to retrofit cruise. Worked out fine, although my IDS always states a programming error. Seems to be a chinese problem, as programming goes fine up the BCM...
But now I have discovered 2 small problems:
1. I have no high beam anymore. When I turn ignition on, I can use high beam, the blue control lamp appers when pulling the lever. But as soon as I turn the light switch to parking or driving light, the main beam goes on, and the high beam switch doesnt do anything....no high beam, no blue control lamp
2. my taillights are completely dead. Indicators, brake, reverse and fog light are working. But not the standart red driving light (dont know the english word).
Can this be programmed in module parameters, and if then how are the options called?
help pls :?
Hovervan
Re: BCM problem / no high beam / no taillights
Postby loot » Fri Jun 30, 2017 10:07 am
I think you have the program for chassis cab and not for van.
Can you install correct asbuilt for your vin number
07 350 170ps
Ids map here
loot
Postby Hovervan » Fri Jun 30, 2017 10:15 am
Tried that....downloaded the file at motorcraft and let IDS download it on its own - same error.
This digital 1 1 0 1 0 1 0 1 0 1 0 1 s**t starts to piss me off.... :roll:
Hovervan
Postby loot » Fri Jun 30, 2017 10:21 am
There's corrupt files thanks motorcraft :roll:
Pm me your vin number m8 I'll have a look
07 350 170ps
Ids map here
loot
