robbie.cee wrote:Thats one way to change a gasket!
robbie.cee wrote:Good luck and what dash you got, jag or van cos we all know van temp gauge pretty vague and normal goes from like 80 to 120°c ...
I found my cossie v6 preferrs to be a bit hot than bit cold and also traffic is worst not so much cos of lump temp but more drawn in air is fkn baking from bay heat... i seriously need either some sorta wall like the fiestas get to shield air filter or a proper air box with the trumpet that points to headlamp
robbie.cee wrote:Am i right in thinking arch roller is arm bolts to hub with hydraulic ram to push arm with roller outwards to do arch? Sure i seen that on tv once
robbie.cee wrote:Vid that pls. Was thinkin of makin one but be better off just doing springs and space sld rail a mm or 2
robbie.cee wrote:Rolling wont do more than pull arches outwards more so more likely to rub aint it? On the door i mean
Pocketrocket wrote:robbie.cee wrote:Rolling wont do more than pull arches outwards more so more likely to rub aint it? On the door i mean
Na im not flaring them just rolling the lip on the inside, its that thats catching the tyre wall, i recon once thats rolled it'll be sound
