Mk1 and 2 independant front suspension conversion!
Re: Mk1 and 2 independant front suspension conversion!
Postby RP123 » Wed May 15, 2013 10:29 pm
Some pictures with the wheels on.
1999 Tourneo GLX85PS
1973 Mk1 Transit Canterbury savannah
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Postby RP123 » Wed May 15, 2013 10:30 pm
Couple more
1963 Mk3 Zodiac
1964 Anglia 105e
RP123
Postby Luke » Wed May 15, 2013 11:10 pm
perfect width then 8)
Postby Lordbongo » Tue Jul 14, 2015 6:15 am
After Reading the Hole thread i am just wondering about this.
Will any parts from an 72-85 ford granada be useble on the front of a 71 transit.
I know it will need to be some mods done.
But i have a lot of granada spares an it would save a lot of cash.
Thinking about stering rac (power stering) and spindles ( disc breaks)
Maybe it is posdible to put in the Hole front suspensjon ?
Tjanks fore any reply
Jon
Love of old Fords is an hazard they tend to multiply.
Lordbongo
Postby Colin55 » Wed Nov 29, 2017 10:43 am
Luke,
I see this thread has generated a lot of chatter. So, apologies for adding to it.
Are there only the four photos of your conversion on here? Because reading the thread implies there are more somewhere. But, I can't find them.
I'm planning to do the conversion on my SWB Mk1, so any information, hints or tips will be greatly appreciated.
Colin
Colin55
Postby Luke » Wed Nov 29, 2017 11:12 pm
thats all of them im afraid - i did the conversion before the days of camera phones so it wasn't as convenient to take photos
anything you want to know just ask :D
hints and tips do its just like ive done (on the 2nd one) but copy brownysv6's idea with the rear mounts using a captive nut in box section welded over the chassis rail - thats the only thing i plan to change on mine only to make it look more 'factory' :D
Postby Colin55 » Thu Nov 30, 2017 10:08 am
Luke,
The only things that concern me at the moment are the camber and castor angles, and how to get them correct.
I haven't got a donor vehicle yet. I'm sure there'll be many more questions once I do.
Thanks,
Colin
Colin55
Postby Luke » Thu Nov 30, 2017 9:40 pm
when i did it donors were more plenty-full so i used a scrap front frame and welded it together while it was on the donor van (fit new bushes 1st) then chop it out
this was all scrapped after i used it
even if i had one van i'd still do this just fit new shocks after then clean up the parts i'd welded to :idea:
this will get the top mounts in the exact position - the camber will be spot on and the castor will set its self - you cant really get it wrong :D
Postby Colin55 » Thu Nov 30, 2017 10:16 pm
Luke,
That's excellent, thanks.
I've found a van (through this site), but it doesn't have power steering, which is something I want.
I was wondering whether it could be fitted afterwards? Providing, of course, that I can get a power steering rack.
Colin
Colin55
Postby Luke » Thu Nov 30, 2017 11:38 pm
Colin55 wrote:Luke,
Colin
yes exactly the same mounts etc. pas rack will just bolt on
only thing to be careful of is the pas rack is wider on the base of the column so if your swapping an engine in then better to get the pas rack before you mount anything close to it
Postby Enzolly » Fri Nov 30, 2018 12:13 pm
Luke,
Did you weld any other plates other than those from the shock to the subframe before you removed the IFS from the donor?
And perhaps a stupid question but did you weld them while it was resting on it's wheels? I guess yes?
Cheers Enzo
Verstuurd vanaf mijn G8141 met Tapatalk
Enzolly
Postby Luke » Fri Nov 30, 2018 6:03 pm
Enzolly wrote:Luke,
Cheers Enzo
i sort of did i took the springs out and replaced the strut top bearings with solid steel ones but yes with the weight on to get it level
long time since i did it but i dont think any other plates were welded on
Postby Enzolly » Fri Nov 30, 2018 6:15 pm
Ok. I'm going to try to weld the plates while it's on it's wheels.
Do the strut tops have that much play, so you had to replace them with solid ones to get them in the right place?
Enzolly
Postby Luke » Fri Nov 30, 2018 6:33 pm
basically i was fitting new strut tops anyway as there was a slight bit of wear so i just welded them up but you dont need to if they are good
Postby Enzolly » Fri Nov 30, 2018 6:37 pm
Ok. Thanks Luke.
Just going to check the track width of the donor mk5 (96-00) and if that is close enough to my mk1 I'm going for it.
Enzolly
