NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIGHT
Re: NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIG
Postby bigjohnthomas » Tue Jan 23, 2018 12:51 am
A wink ? It meams ay ay lad crack on ,your doing a good job n all that :wink:
At least it did when I was a kid anyway :?
I suppose you disgusting creatures use it for to describe something pervi these days :roll:
bigjohnthomas
Postby Redt4 » Tue Jan 23, 2018 2:07 pm
So if the egr is mapped out on a mk7 how will the mot station know?? Asking as it's something I have been looking into but don't want an mot failure due to it.....
Redt4
Postby jumbo 57 » Tue Jan 23, 2018 2:22 pm
EGR operating correctly lowers NOx,
Tis that they will be testing methinks.
High NOx outwith manufactures specs = FAIL (perhaps some leeway factored in, as per other emission testing)
jumbo 57
Postby mike113 » Thu Jan 25, 2018 12:49 pm
I take it we will all have to unblock our EGR valves now then
mike113
Postby paul2012 » Thu Jan 25, 2018 5:00 pm
mike113 wrote:I take it we will all have to unblock our EGR valves now then
Yes EGR valves that have been removed or tampered will be a MAJOR defect & result in automatic MOT refusal.
I politely warned this Forum nearly 2 years ago of these impending changes for MOT rules. People are still saying it will never happen. :roll:
Well it's just been made public
:arrow: https://www.express.co.uk/life-style/ca ... iesel-cars
:arrow: https://www.thesun.co.uk/motors/5421565 ... esel-fail/
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Honda415 » Tue Feb 06, 2018 4:52 am
I was always under the impression that emissions were better with an egr blank? Anyone know what the pass rate would be for mine as i might take it to get a voluntary emission test prior to the mot? Looks like i will take out the blank the day before and refit the day after worst case.
2006 Mk6 115 T350 Jumbo to be a workhorse once it works then potential motocross van.
Honda415
Postby paul2012 » Thu Feb 08, 2018 8:12 pm
Honda415 wrote:I was always under the impression that emissions were better with an egr blank? Anyone know what the pass rate would be for mine as i might take it to get a voluntary emission test prior to the mot? Looks like i will take out the blank the day before and refit the day after worst case.
Manufacturers emission limit will be listed on vehicles VIN label.
From 20th May2018.All diesel emissions will be tested against that limit.
EGR valve is part of emissions control. :idea:
EGR valve blanking plate fitted.....
Emissions control equipment fitted by manufacturer Missing, Obviously modified or Obviously defective - Major defect = MOT REFUSAL.
Remove blanking plate. :wink:
paul2012
Postby andz327 » Thu Feb 08, 2018 8:54 pm
How would that go with mk7 fwd with mk6 tddi in it ??
andz327
Postby Honda415 » Fri Feb 09, 2018 2:34 pm
Good question i know kit car builders etc who have to write to the manufacturer of there donor engines to get the manufacture date etc in order to get the emission limit as well as an age related nunber plate etc. Might have to do something like that.
Honda415
Postby paul2012 » Fri Feb 09, 2018 10:55 pm
Honda415 wrote:Good question i know kit car builders etc who have to write to the manufacturer of there donor engines to get the manufacture date etc in order to get the emission limit as well as an age related nunber plate etc. Might have to do something like that.
Different engines - New rule applies...
Vehicles first used on or after 1 September 2002 fitted with a different engine must to tested to the requirements relating to the age of the vehicle.
If an engine has been modified in any way, it still has to meet the exhaust emission requirements according to the age of the vehicle.
paul2012
Postby karl » Fri Feb 09, 2018 11:01 pm
mines been blanked for years and it still passes ever smoke test
karl
Tranny Lover!!!
Postby karl » Fri Feb 09, 2018 11:05 pm
in reality the thing they are targeting is new ones, lets say from 2012 on wards :D
karl
Tranny Lover!!!
Postby paul2012 » Fri Feb 09, 2018 11:09 pm
karl wrote:in reality the thing they are targeting is new ones, lets say from 2012 on wards :D
More like vehicles 1st used from 2001 onwards :wink:
paul2012
Postby karl » Fri Feb 09, 2018 11:16 pm
well how does mine pass ever time then no engine light, not black or blue smoke :roll:
also i have been behind a few tesco deliver vans that smoke all the time. " well they re iveco " :lol:
anyway i do know the hauliers are getting it
http://www.commercialmotor.com/news/com ... e-emulator
karl
Tranny Lover!!!
Postby paul2012 » Fri Feb 09, 2018 11:19 pm
also i have been behind a few tesco deliver vans that smoke all the time. " well the are iveco " :lol:
anyway i do knbow the hauliers are getting it
For EGR valves it's a visual check for the moment as of May 20th 2018. So if it been removed or tampered with ie blanking plate fitted. It's a major defect.
It applies to all Diesels including Petrols. :wink:
paul2012
Users browsing this forum: Sports140
