Hovervan wrote:Just want to throw in that no one shall be messing around with chinese VCM II trash anymore, as Forscan is now capable of nearly anything what IDS can do.
So save yourself monies and nerves, get a ELM cable for a tenner and be happy.
davyjcb wrote:Yes have done 2
davyjcb wrote:If you register for an extended license it can perform module programming, pats functions, cal steering angle,dpf regens any incodes required are generated when you perform whatever task you are doing,it will ask if you want forscan to generate code or if you want to use an external code generator so far I have found it easier to do basic stuff on but ids still has the edge for adding extra's on like cruise and snowflake as the engineering menu gives you plain text options to add whereas forscan has to be played with to change parameters.If someone could do a spreadsheet comparing file details before and after pcm/bcmi software changes it would make the need for ids nearly redundant
loot wrote:The need for ids was worthwhile on the mk7 vehicles to 2012 but with more stringent access to pats and less requirement on the Siemens system I can't see the need.
I have no need to use ids on my custom and i couldn't program keys etc so rarely go on it.
So an occasional home user won't want to spend serious money on it.
And i think forscan can access early euro 5 etc.
Otherwise 80 pounds at the dealer might be cheaper than the time and effort trying to get my own kit.
