now fitting a mk5 transit front on my mk3 recovery truck.
Postby mk5 transit recovery » Thu Nov 17, 2005 12:25 pm
cruiseing down the m25 last nite at 8pm at 80mph & BANG! truck rolls 2 a stop!!! :?
whats wrong????? :?:
the gearbox has self destructed & is missing half the bellhouseing & box is snapped in half!!!!
lovely waiting 3 hrs in the freezeing cold waiting to be recoverd, then another 3 hrs sitting in a freezeing truck that wont start (no heaters) being towed 150 miles home!!
had 2 have the windows open all the way home 2 stop the screen steaming up, got home at 4.30am!!!!!!
but Mmmmmmm did my bed feel warm when i got in it! :D
will get pics of the box 2day & post up
Last edited by mk5 transit recovery on Thu Nov 17, 2005 11:16 pm, edited 2 times in total.
Postby jay » Thu Nov 17, 2005 4:22 pm
ouch!! :cry: So that will be a new box then..was that a type n or mt75 you have??
mk1 connect tourneo
jay
Postby madmark » Thu Nov 17, 2005 7:23 pm
wow i have never herd of a mt75 dooing that before! :shock:
Postby Gunslinger » Thu Nov 17, 2005 7:58 pm
i have, with mt75 boxes, and i am assuming this is what you had
before you consigne it all to the scrap heap, get underneath and take a carefull look around the bellhousing and mountings and see if you can identify where it failed .... my bet is the lower 4 and 8 o'clock positions .....
now take a look at the engine mounts you have, and i'd bet they dont have the outriggers that branch back to the gearbox do they ? ... bet your next set of mounts will have!
they should look like this
EDIT! .... forgot to say get over to ebay now as there is about 4 or 5 mt75 boxes on there at the moment so you should be able to get one fairly cheap :)
Gunslinger
Postby mk5 transit recovery » Thu Nov 17, 2005 8:18 pm
looked under it mate as had 2 take prop off b4 it could be moved as was all jumping about.
carnt see why box failed? its split in half across ways & has also split bellhouseing in half near starter moter.
needs :
mt75 box
clutch
flywheel (ring gear fooked)
starter (maybe)
gave it 2 a local garage who supplying & fitting all above for £240!!!! not worth doin it myself 4 that price
Postby mk5 transit recovery » Thu Nov 17, 2005 8:20 pm
Gunslinger wrote:i have, with mt75 boxes, and i am assuming this is what you had
[img]
http://i4.photobucket.com/albums/y125/F ... mounts.jpg[/img]
u reckon i need new mounts?
Postby Gunslinger » Thu Nov 17, 2005 10:05 pm
it would not be the first time that the link between aluminum gearbox and cast block has given up the ghost ... bear in mind the torque involved, and the mounting positions, you have the rear gearbox support (right at the back) the engine mounts, that are further forward than the balancing point of the engine alone, combine this with the gearbox front end weight, and you have a bit of a weak point, hence the engine mounts that branch back to the g/box lower mounting area.
I could be wrong, but i beleive this is the reason for the redesigned mountings, to save this type of failure on high torque applications
EDIT .... forgot to say, all above said and done, there is probably plenty of mt75 boxes out there running fine without these extra support mountings and probably will be for many years to come
Gunslinger
Postby Gunslinger » Thu Nov 17, 2005 10:22 pm
mk5 transit recovery wrote:looked under it mate as had 2 take prop off b4 it could be moved as was all jumping about.
needs :
mt75 box
clutch
starter (maybe)
sorry for the 2 replies, only saw the last one in the window when i came into the thread at first.
the damage to the box (ie splitting in half) is making you wonder if something broke, jammed up and then caused the box to grenade itself, right? well very hard to determine if something inside caused the destruction, Especially as you were doing 80 at the time, if the box cracked around the bell housing and then seperated at an angle, it would probably cause enough of a problem to effectively seize up, reversing the normal power transfer from the engine to the back wheels, to the wheels and forward motion (plus the vehicle weight) trying to drive the engine through the gearbox, if it seized up in the clutch area (or g/box side of clutch) i could well beleive the forces involved caused the internals of the box to be forced apart, fracturing an already damaged casing past the point of its strength
Gunslinger
Postby mk5 transit recovery » Thu Nov 17, 2005 10:37 pm
as ive said mate, dont know why it done it but just hope it doesnt happen again! but pretty sure its gone bang from inside 4 sum reason?
im haveing gearbox,flywheel & clutch fitted so any damaged it may have caused should be fixed!
this is 1st problem ive had with the truck since ive had it so not bad goin i supose
Postby Gunslinger » Thu Nov 17, 2005 10:44 pm
mk5 transit recovery wrote:this is 1st problem ive had with the truck since ive had it so not bad goin i supose
a smaller problem would have been nice though.
when you get the pics of whats left of the g/box, post them up, i'd love to see them. what did recovery guy that saw it say ?
i know your going to be curious after a little while to what might have caused it, so if you do find some info i too would be interested :)
cheers, and good luck, hope it didn't cause any other damage and your up and running again soon
Gunslinger
Postby mk5 transit recovery » Thu Nov 17, 2005 10:48 pm
didnt get it recoverd on a truck (£500 then £80 every hour!)
got a good mate 2 come out in his transit chassie cab (truck soon) with a towing bar & towed it all the way home (with no heaters!)
broke down at 8pm & got home at 4.30am this morning
will try get pics of the box 2morra if the bloke still ha sthe old box there but appart from that i have a pic on my phone i'll post up later if its anygood.
Postby bortaf » Thu Nov 17, 2005 10:58 pm
I hate nights like those :(
still thats a dam good price to repair it, your right i wouldn't even get me tools out for that price :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Gunslinger » Thu Nov 17, 2005 11:11 pm
:shock: i overlooked that price, dam i need a local garge like that :P
Gunslinger
Postby mk5 transit recovery » Thu Nov 17, 2005 11:15 pm
Gunslinger wrote::shock: i overlooked that price, dam i need a local garge like that :P
tell me about it & best thing is i took it in at 1 o'clock 2day & went past at 2pm & it was up on the ramp in bits & i get it back in the morning!
how about that for service!
dont get service with a smile but for that price it put a smile on my face! :)
Postby mk5 transit recovery » Thu Nov 17, 2005 11:46 pm
right here is the pic of my phone
anybody wondering whats up then here u go
basically the 2 blue lines should line up but gearbox has snapped in half & rear half has dropped down & where the blue X is is the flywheel & clutch (bitg bit of bellhouseing missing)
