What did you do to your Custom today?
Re: What did you do to your Custom today?
Postby bigjohnthomas » Wed May 16, 2018 8:00 pm
You've drilled holes to fasten the toolbox down?
It will rust like a rusty thing get some red lead on it quick
I'm going to hand paint billys undercarriage with red oxide then stone chip next week
It's beyond a quick squirt of stonechip now
Rusty rusty
I thought he might keep a bit better than the lime did with not going through a river everyday
But he hasn't
Bloody ford
bigjohnthomas
Postby loot » Wed May 16, 2018 8:19 pm
bigjohnthomas wrote:You've drilled holes to fasten the toolbox down?
Rusty rusty
But he hasn't
Bloody ford
No the floor is full of holes from the hilti it's like a fooking t bag there holes for nuts and bolts and there's also rivnuts all over so I've just put the bolts in either side of the toolbox and there's strap hook things from hilti that I've ratchet strapped too.
The flooring is some kind of composite stuff and is sealed around the edges, I should really remove it and seal the holes but I'm tempted to try and buy some rubber grommets to just push up from underneath with some sealant in.
The van won't pass these new mot anyway I'm sure so I'll need to buy a new 1 :lol:
07 350 170ps
Ids map here
loot
Postby cycleguy » Sun May 27, 2018 5:27 pm
Got a good bit done on my hifi install
cycleguy
Postby cycleguy » Fri Jun 01, 2018 10:28 pm
Front speakers all mounted wired in and the doors fitted with plenty of sound deadening the new speaker on the right should sound a lot better
cycleguy
Postby Camper steve » Thu Jun 07, 2018 11:08 am
nice system, what speakers did you install?
Camper steve
Postby TallPaul » Thu Jun 07, 2018 6:04 pm
3.8M length in a SWB Custom...
TallPaul
Postby cycleguy » Fri Jun 08, 2018 7:27 pm
Camper steve wrote:nice system, what speakers did you install?
I have put SB acoustics mids with Vifa XT25series tweeters and the sub is a infinity 8 inch
cycleguy
Postby cycleguy » Sat Jun 09, 2018 7:05 pm
Today I sanded the texture off the mirrors and small panel in front of it and gave them a coat of black basecoat and a nice gloss with clear coat
cycleguy
Postby loot » Sat Jun 09, 2018 8:15 pm
Shiny :P 8)
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Sat Jun 09, 2018 11:07 pm
2 apples and a banana 8)
bigjohnthomas
Postby cycleguy » Sun Jun 10, 2018 10:53 pm
Back on the van nice improvement
cycleguy
Postby jue » Mon Jun 11, 2018 10:56 pm
Painted the front Break Calipers
jue
Postby AusTansit » Sun Jul 08, 2018 10:13 am
Installed a nudge bar and LED light bar.
Low beam.
High beam with LED light bar.
AusTansit
Postby bigjohnthomas » Sun Jul 08, 2018 5:44 pm
It's a tad bulbous init?
Bloody wheel bearing is rumbling on mine :x
Sounds like it a back one :? So it's probably a front one :lol:
Bloody Ford :x
bigjohnthomas
Postby loot » Sun Jul 08, 2018 11:27 pm
My left mirror was making a squeak or catching noise when operated, I thought it was the bjt overuse curse but ice lubed it up and it is quiet again :-)
Also I was diving on the autobanned today and my speedo showed the driver door open on the van picture display. But the door was shut :? The custom is just a tarted up trampy mk7 really isn't it :cry: but a key cycle has got rid of it.
07 350 170ps
Ids map here
loot
Return to Transit Custom
