Glow Plug
Glow Plug
Postby Aztran » Fri Nov 18, 2005 2:06 pm
Has my van got one?
Theres no light or such on the dash..............
And what Mark is mine?
95' Transit 190 LWB
:P
2000 x, new style Transit 350!
Aztran
Postby madmark » Fri Nov 18, 2005 2:11 pm
no mate your van hasnt got one! if you are haveing starting problems make shure your battery is perfect you need as much cranking power as you can get! then she should start no problem! :)
Postby Aztran » Fri Nov 18, 2005 2:18 pm
Starts on first turn key, but mis fires quite a bit and chugs, only for 10-20 econds mind...........wether it be winter or summer
Aztran
Postby MrMPuk » Fri Nov 18, 2005 3:03 pm
That's quite normal for a diesel. I for one would say that you've got a Mk5, others may argue that this is incorrect, but 90% of people would know what you are talking about!
Postby Aztran » Fri Nov 18, 2005 3:15 pm
Thanks for the info..............
Aztran
Postby jay » Fri Nov 18, 2005 7:41 pm
if you getting a misfire when starting it could be dirty injectors.or leaking injectors.
mk1 connect tourneo
jay
Postby Nighthawk » Fri Nov 18, 2005 10:54 pm
You'll only have a cold start device if it was specc'd when first ordered.
It's a flame start device, this means diesel is sprayed onto a red hot coil and acts like a blow torch down the inlet manifold. Very visable once the bonnet is open.
If the idle is a little unstable when first running, i'd make sure that the fuel supply is ok, small air bubbles or fuel drain back will take a few seconds to clear once the pump starts to supply diesel.
Nighthawk
