problems starting
problems starting
Postby mauricew » Tue Nov 22, 2005 10:14 am
I have a transit van with no glow plugs ,each time there is a cold spell I have problems starting ,even bought a new battery ,is there anything i can do before stsrting to remedy this problem and to get me started on these cold mornings.
mauricew
Postby FredTransit » Tue Nov 22, 2005 11:23 am
Have a look over on the Mk3 board, you don't say what year yours is, but the principle is the same.
FredTransit
Mk2 Trannyist
Postby Luke » Tue Nov 22, 2005 1:33 pm
im guessing its a Di - how does it start normally , a Di in decent nick should start instantly! if it doesnt that will be the problem - and only get worse when its cold!! :D
cold starting
Postby mauricew » Tue Nov 22, 2005 2:27 pm
Its a d R reg 2 .500 cc had a new heavy duty diesel battery fitted lasdt week but still probns starting on cold mornings
mauricew
Postby madmark » Tue Nov 22, 2005 4:09 pm
:? sounds abit like the feul is draining back to the tank somehow! :?
Postby dan@dsfplumbing » Tue Nov 22, 2005 4:11 pm
Yeah is it just slow turning or does it turn away merrily with no fire-up ??
dan@dsfplumbing
Postby rover » Tue Nov 22, 2005 5:47 pm
I would guess that its either a fuel starvation problem or the starter is dragging to many Amps.
Kev.
rover
cold start
Postby mauricew » Tue Nov 22, 2005 6:37 pm
it turns over merrily but no fire up,someone said press twice on accelerator then turn ignition key
mauricew
Postby mauricew » Tue Nov 22, 2005 6:38 pm
if it is strater dragging too many amps how do i go about correcting this,anyway thanks guys for your help
mauricew
Postby rover » Tue Nov 22, 2005 6:57 pm
If it turns over pretty quick then the starter if fine...
It may be just as simple as replacing the Fuel filter, which is the first thing I would suggest as its cheap.
Kev.
rover
Postby FredTransit » Tue Nov 22, 2005 8:15 pm
mauricew wrote:if it is strater dragging too many amps how do i go about correcting this,anyway thanks guys for your help
Replace it. It might just be behaving like a flat battery cos of the starter.
FredTransit
Mk2 Trannyist
cron
