Front shocks and spring replacement Mk5 190
Postby Fo-Banshee » Fri Mar 29, 2019 9:54 am
I'm changing my front coil springs and shocks in my MK5 2.5td LWB. Looks to be a pretty standard sort of setup and easy to get to ,except the springs are a little more heavy duty then the cars I've worked on. If anybody has changed theirs, is there anything I should watch out for or need to know beforehand thats specific to the transits? cheers in advance.
Transit VG 07/2000 4EB 2.5tdi Mid roof Lwb (camper), VG 1999 3.8ltr V6 LWB, VG 1997 3.8ltr V6 LWB and a Transit VG 09/1996 4EB 2.5tdi Low roof Swb (spare parts)
Fo-Banshee
Re: Front shocks and spring replacement Mk5 190
Postby Mislaid » Fri Mar 29, 2019 11:56 am
Dead easy, shock off(unbolt top before jacking) and spring will come out. No compressor required
Mislaid
Postby Fo-Banshee » Fri Mar 29, 2019 7:49 pm
Thanks Mislaid, it looked straight forward. Visually same setup as a few ford sedans I've worked on. I'm fitting the King springs raised coils 20mm higher than stock. The old are a little saggy and the weight of the bullbar doesn't help. Going to fit Gabriel gas shocks which a friend recommended and turned out to be well priced.(if I call them cheap I feel uneasy) :wink:
Fo-Banshee
Postby Chug » Fri Mar 29, 2019 10:36 pm
yeah pretty straightforward job and easy enough to suss out when your looking at it and think about it. :D
Chug
Postby dermo7 » Sat Aug 30, 2025 5:16 pm
How were the Gabriel shocks Fo-Banshee?
dermo7
