Lucifer in progress
Re: nedforceone in progress
Postby ned » Fri Aug 02, 2019 7:09 pm
I know that feeling, I removed my spot/fog lights well over a year ago and still haven't finished making the bracket for them :oops:
Right suppose I should go plug the van in and see why it's being a bitch.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Fri Aug 02, 2019 7:23 pm
God speed mr Ned 8)
07 350 170ps
Ids map here
loot
Postby ned » Fri Aug 02, 2019 7:31 pm
Well that looks fine 8)
ned
Postby ned » Fri Aug 02, 2019 8:05 pm
Thinks that bleedin wiring fault has come back, guess what I'll be doing tomorrow.
ned
Postby ned » Sat Aug 03, 2019 6:56 pm
Well started off with the plan of re-wiring the fuel pump but plans change quickly,
Turbo looks a bit sooty :? But no play in there,
Then spent a hour stripping the loom out to check the wiring,
Rewired the fuel pump :P
Found a nice split in the boost pipe,
Looks like it's been rubbing on a nut or something :x at least I know where my boost leak is now,
Just about to retape the wiring up and refit the plastic sleeves when I spotted this,
Bloody CHT wire melted/chaffed, need to fix that now :roll:
But I did fit nice clean new inlet manifold gaskets 8)
Hope the bloody van appreciates all this attention.
ned
Postby ned » Sat Aug 03, 2019 7:12 pm
Bit of an update from a few months ago,
Rear window film fitted,
HID headlights fitted, big thanks to Mr Andz for the kit,
Need to go out at night for some pictures.
Still to do,
Paint the front wing from the good Mr Altransit,
Paint the tailgate from the good Mr Loot,
Fit both said items and tackle the rust spots on the van, jobs are never done :roll: :lol:
ned
Postby loot » Sat Aug 03, 2019 11:19 pm
Looking productive, turbo may even pass oil film so soot should be fine.
I'm after a tailgate :lol:.
You should get some zip ties and look for any wobbly pipes or looms or brackets etc and loosely tie them out of the way. 8)
07 350 170ps
Ids map here
loot
Postby bambi mk 1 » Sat Aug 03, 2019 11:30 pm
loot wrote:Looking productive, turbo may even pass oil film so soot should be fine.
He should also wash his hands as the vans a mess :lol:
bambi mk 1
Postby Jay2018 » Sat Aug 03, 2019 11:35 pm
The rear window tint is awesome. I have rear barn doors, but deffo want to do something like that on the window indent.
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Postby ned » Sun Aug 04, 2019 7:29 am
I have a tailgate here if you want one, most dents are filled, I just need to replace the glass after a wee accident :oops:
ned
Postby ned » Sun Aug 04, 2019 7:32 am
I know it's shameful innit, starting work on the van with dirty hands :oops: got in trouble for turning the bath black :lol: :lol:
ned
Postby ned » Sun Aug 04, 2019 7:34 am
Jay2018 wrote:The rear window tint is awesome. I have rear barn doors, but deffo want to do something like that on the window indent.
9 sovs off the bay of e 8) chingchongs finest window film, not sure if it'll stick to metal, might do :?
ned
Postby ned » Sun Aug 11, 2019 2:16 pm
Made a leak back test kit,
So did a leak back test, may as well as I made the kit :lol:
Happy with the results, I think,
Bottom red line 25ml top red line 50ml, no2 cylinder looks very low all the rest are at 25ml.
Now I've rewired the fuel pump, done a leak back test and the van still goes into limp mode so next change the fuel filter, buy a new imv, wondering if the throttle pedal might be iffy, it has had 220,000 miles of use, expensive part if it's not faulty.
ned
Postby ned » Sun Aug 11, 2019 4:03 pm
https://www.pfjones.co.uk/ford-transit- ... a130b.html
Seems a fair price, might have to bite the bullet and buy one :?
ned
Postby loot » Sun Aug 11, 2019 7:55 pm
You not getting any fault codes? Have you had ids on it?
07 350 170ps
Ids map here
loot
