What did you do to your connect today?
Re: What did you do to your connect today?
Postby KeithC » Thu Apr 09, 2020 5:18 am
oooooooooooh. What model did the new wheel come off of? (I'm presuming 'Focus' but a mk1 or what?)
Will you miss the feel of crumbling foam beneath your fingertips?
:arrow: 2007 Transit Connect 220 Hi-Top.
193,000 km, still rolling and rattling.
MK1 Focus air intake
Clean engine bay
Bulkhead
Yet to do:
Custom centre console
Deadmat
Plyline
De-rust & respray skirts
Clean Air Intake Manifold
Waxoyl underside
KeithC
Postby blue estate » Thu Apr 09, 2020 8:16 am
KeithC wrote:oooooooooooh. What model did the new wheel come off of? (I'm presuming 'Focus' but a mk1 or what?)
Mk6/7 Fiesta straight swap
MGS5 and MG5
VOLVO FH daily drive
blue estate
Postby blue estate » Thu Apr 09, 2020 12:03 pm
Look mother no sub frame
Here it is
One of my ARB bushes
And here’s the hubs
MGS5 and MG5
blue estate
Postby blue estate » Tue Apr 14, 2020 4:25 pm
Put back the floor mat after putting down some new sound deadening foam as old fibre mat was shot ,
Also put drivers seat back in and centre console
MGS5 and MG5
blue estate
Postby RustWidow » Tue Apr 14, 2020 10:21 pm
You’re doing well blue
RustWidow
Postby KeithC » Mon Apr 27, 2020 3:48 am
@UCmanster, Thank You! Adding that to the list...
@ Blue Estate, That looks good, that'll be the next undertaking for me. (Once I've done some household tasks; Keep the missus happy, make the hacienda nice. Can't just hide in the van for the entirety of the quarantine...)
Today I got around to swapping out the stock airbox and intake for a mk1 Focus intake. I also removed the intercooler and every bit of ducting from intake to throttle to give it a good scrub, and due to my " unnecessary* " cleaning I found several new holes in the cold air feed pipe, so I replaced that with an el cheapo soft rubbery copy. Also found one of the IC pipe struts had snapped clean half in two, so I fixed that. And resprayed the heads of the bolts I removed. And did same for the bonnet lock brace.
Got it all back in and tightened up, and went for a spin. I cannot believe the difference.
The van actually accelerates as I press down on the pedal... Like immediately, not just eventually. Chuffed to bits! :D
*My neighbour takes great joy in slagging me off for spending so much time at the van. "If it ain't broke don't fix it" etc. Some people just don't get it...
Clean engine bay
Bulkhead
Yet to do:
Deadmat
Plyline
Waxoyl underside
KeithC
Postby ConnectCamperFDC » Mon May 11, 2020 10:51 pm
Testing out different wraps on my grill, do you think it looks a bit gay or is it ok?
ConnectCamperFDC
Postby mrtn » Tue May 19, 2020 1:55 pm
ConnectCamperFDC wrote:Testing out different wraps on my grill, do you think it looks a bit gay or is it ok?
Don't stop there. Go all the way.
1.6 Ecoboost A/T LWB '16
mrtn
Postby ConnectCamperFDC » Thu May 21, 2020 10:50 pm
That would look nuts mate but trying to keep it a bit lowkey for when i am camping in it, changed it a bit today tho.
ConnectCamperFDC
Postby mrtn » Sat May 23, 2020 9:32 am
Perhaps some grayscale bar would be smoother, that black one sticks out like a sore thumb. Or the original double rainbow bar.
mrtn
Postby MaDDogg » Sat May 30, 2020 8:05 pm
Just bought the van so got two new keys cut and programmed.
MaDDogg
Postby KeithC » Mon Jun 01, 2020 4:50 am
@MaDDogg
Neat! Where'd you go for that?
Clean engine bay
Bulkhead
Yet to do:
Deadmat
Plyline
Waxoyl underside
KeithC
Postby KeithC » Mon Jun 01, 2020 6:59 am
Clean engine bay
Bulkhead
Yet to do:
Deadmat
Plyline
Waxoyl underside
KeithC
Postby MaDDogg » Mon Jun 01, 2020 1:43 pm
KeithC wrote:@MaDDogg
Place called carkeysbanbury.co.uk
He is local to me and was very helpful.
Supplied, cut and programmed two new keys and even replaced the battery in the original I had.
Took about 25 mins.
MaDDogg
Postby ConnectCamperFDC » Mon Jun 01, 2020 10:39 pm
Ahh man looks like i am going to have to try wrap the whole thing now haha cheers
ConnectCamperFDC
