TheDrunks - Ex-BT Van project
Postby TheDrunk » Thu Jul 12, 2007 5:49 pm
6471mc appears to be a belt for models with power steering. I am convinced I need the 4PK1520 now.
Crazy BT van man.
TheDrunk
Postby Retrohowla » Thu Jul 12, 2007 5:57 pm
Gates are considered in the pattern part world to be good, quality i have been led to believe. I have one on the mk4, one on chav and the sierra before that, none expired prematurely...........um, touch wood?
:shock:
If you own a transit, learn to weld
Retrohowla
Postby TheDrunk » Fri Jul 13, 2007 8:14 pm
Well well well.
Just got the van home, complete with MOT Pass.
All in all cost me 340 to have the rear cross member welded up, rear arches 'touched up', new brake pads and discs at the front, clean up of areas near the shocker tops, clean up of the brake lines, included the cost of the MOT.
Was advised not to bother about the oil leak on the rear axle, just to get the correct oil, top it up, and wipe down the area and see if it comes back.
So, I will be taxing it tomorrow and will be bringing it along to the Transit meet on Sunday. See you there...... :roll:
Crazy BT van man.
TheDrunk
Postby Luke » Fri Jul 13, 2007 8:52 pm
TheDrunk wrote:Well well well.
:lol: well donr mate - see you there :D
Postby TheDrunk » Fri Jul 13, 2007 9:42 pm
Will my transit be a Type N or MT75 Transmission?
How to tell? :)
Just trying to get the right oil for it.
Crazy BT van man.
TheDrunk
Postby Luke » Fri Jul 13, 2007 10:00 pm
TheDrunk wrote:Will my transit be a Type N or MT75 Transmission?
How to tell? :)
mt75 :D reverse under 5th
Postby gemini » Fri Jul 13, 2007 10:48 pm
Retrohowla wrote:Gates are considered in the pattern part world to be good, quality i have been led to believe.
they make the belts for mitsubishi
gemini
Postby TheDrunk » Sat Jul 14, 2007 7:37 pm
Picked up the correct belt this morning. Also managed to get correct transmission and rear axle oil too :lol:
Crazy BT van man.
TheDrunk
Postby djswampy » Sat Jul 14, 2007 8:46 pm
Going good so far then.
djswampy
Postby TheDrunk » Sun Jul 15, 2007 12:11 pm
just changing the fuel filter over but running into problems...
i cant get the water sensor off the bottom!!!
It is yellow with a black part which looks like the screw that holds it in, this is locked by a bit of the yellow section.
any idea the correct way to get these off? almost breaking it and no joy. :(
also, lost all the fuel out of it, will this be a problem when i put the new one on dry?
tia...
Crazy BT van man.
TheDrunk
Postby WINDSCREENGUY » Sun Jul 15, 2007 12:23 pm
the whole yellow thing just unscrews from the filter
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby TheDrunk » Sun Jul 15, 2007 2:57 pm
Yes, I was a bit hung over this morning!
I managed to work it out on my own in the end, very simple, push in the metal clip on the wiring bracket to disengage it from the sensor unit. Unscrew the whole sensor unit and the seal.
Unfortunately due to the weather, I only managed to change the fuel filter and the air filter.
Also, the bonnet saftey catch release arm broke and we had to take the front to bits to get into the engine compartment! Spliced it up for now with a bit of wire....
Hopefully get the oil done, one evening in the week when the weather is better.
Crazy BT van man.
TheDrunk
Postby djswampy » Sun Jul 15, 2007 5:59 pm
Sometimes it is one problem after another. You'll get there in the end. Eventually.
djswampy
Postby TheDrunk » Wed Aug 15, 2007 6:08 pm
Decided to shift this van on!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0155568786
I just don't have the time to work on this project anymore :(
Crazy BT van man.
TheDrunk
Postby djswampy » Wed Aug 15, 2007 9:42 pm
£1 not a bad price. It was a big project. Well done for trying though.
djswampy
