Mk6 RWD ball joints
Mk6 RWD ball joints
Postby FFMan » Thu May 07, 2020 4:17 pm
Hi
whilst we're all in lockdown getting a few jobs done. Had an mot warning on ball joints last time so bought a pair along with steering rod ends to complete the job.
The Haynes manual says to remove the hub, inc the 425 foot/pound hub nut and stub axle (i'm tooled up but not looking forward to that), but some videos on line either do it on the van, or without removing the stub axle.
Any tips ?
FFMan
Re: Mk6 RWD ball joints
Postby colingo » Fri May 08, 2020 11:28 am
Hi, are you talking about the steering track rods and ball ends ?. if so theres no need to touch the hub, apart from undoing the nut. If your doing the hub lower ball joints im sure ive seen these done with the hub left on.
colingo
Postby ned » Fri May 08, 2020 11:49 am
No need to remove the hub, remove the circlip from the top of the ball joint, use a hammer to knock the ball joint out of the hub and remove from the wishbone. Simples
Refitting the new one, bolt the new ball joint into the wishbone, line the joint up with the hub and using a trolley Jack, Jack it up to press the ball joint into the hub.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby FFMan » Fri May 08, 2020 7:43 pm
sorry = to be clear- you can do all this on the van - just remove the wheel ?
FFMan
Postby ned » Fri May 08, 2020 8:08 pm
Yes it can all be done on the van, remove the wheel obviously and remove the track rod end from the hub thus gives move room to get at the ball joint.
ned
Postby scas » Sun May 10, 2020 11:58 am
dont forget you need a big foppin hammer and big arms :D
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby Airthies » Sun May 10, 2020 1:56 pm
scas wrote:dont forget you need a big foppin hammer and big arms :D
No you don't
Work smarter not harder
..... A hammer may be required to get the tapers out the arms though. Just smack the outside edge of where the taper is directly opposite the arms and they'll usually just pop out.
Do the TRE's first so you can spin the strut to get a better angle at things.
Take out split pin and remove dummy hub shaft nut before removing wheel.
Sent from my A55ho11 using Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby scas » Sun May 10, 2020 3:52 pm
thats a good idea, still need a big hammer to put it in again :)
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
Postby karl » Mon May 11, 2020 10:01 pm
:roll: :roll: :roll: my way is heat them up an hit them with a drift and hammer works all the time :D
karl
Tranny Lover!!!
Postby bambi mk 1 » Mon May 11, 2020 10:17 pm
karl wrote::roll: :roll: :roll: my way is heat them up an hit them with a drift and hammer works all the time :D
:roll: :roll: :roll: :shock: :shock: Idiots guide to shoot yourself https://www.youtube.com/watch?v=TIKFmJXGz1M :shock: NEVER EVER HEAT A BALLJIONT
bambi mk 1
Postby karl » Mon May 11, 2020 10:26 pm
:lol: :lol: :lol: :lol: yes you have reminded me many times before
hgv ball joints get the same treatment 8)
not one has exploded yet
thanks karl :wink:
karl
Tranny Lover!!!
Postby bambi mk 1 » Tue May 12, 2020 12:38 pm
thanks karl :wink:
You might not even hear the bang :wink:
bambi mk 1
Postby Airthies » Tue May 12, 2020 12:58 pm
scas wrote:thats a good idea, still need a big hammer to put it in again :)
Nah..
Just clean the bore well, light bit of oil lube, drop it in the wishbone, line it up and jack it back.up into position. Maybe a light tap to keep it straight at the start but no need smash it
V86+patch
V86.04
X-Prog
C81
Airthies
Postby avromo » Mon Jun 29, 2026 10:56 am
No you don't
With this setup what are you winding out to create the downward pressure
Mk7 2009 T370 140 2.4 rwd
avromo
Postby knobby1 » Mon Jun 29, 2026 7:39 pm
avromo wrote:
No you don't
Thread is over 6 years old...however, our Airthies is still very much active.
Lord Knobrot (Smithy)
