2013 transit custom cutting out
Re: 2013 transit custom cutting out
Postby Paul68 » Sat Aug 22, 2020 5:54 pm
There are 2 black oblong relays mid way he outer one states fuel pump relay
Paul68
Postby Paul68 » Sat Aug 22, 2020 5:58 pm
You're right wrong fuse, fuse 24 I was looing at wrong one there but right relay r12
Paul68
Postby Frag » Sat Aug 22, 2020 5:59 pm
This is the fuse that will be causing your problem.....
Frag
Ford Technician
Postby Paul68 » Sat Aug 22, 2020 6:04 pm
I've just contacted him and told him to check it and the connection to the fuse
Paul68
Postby Frag » Sat Aug 22, 2020 6:08 pm
If he pulls the relay out R12
And puts his test lamp or meter on the terminals,2 of the four should be live from that fuse,wiggling said fuse will almost certainly cause a loss of feed to those terminals.
Pulling fuse out,one side is onto a live bus bar,other out to relay,
Get a sharp pick and tweak them all inwards to grab fuse.
Think you’ll find it’ll be cured.
Frag
Ford Technician
Postby Paul68 » Sat Aug 22, 2020 6:23 pm
He just got back to me said nothing there to see really but he has closed up the connection to make sure it's good, he's not good with this stuff and has had someone guessing with his money, ie buying parts he "thinks" have gone, hopefully this will have cured it
Paul68
Postby Spaceman210 » Thu Sep 10, 2020 1:11 pm
Frag wrote:If he pulls the relay out R12
Hi Frag
I have 2 live connections at the fuel pump relay never faulters. But I don’t appear to have any power from there to pump.
Fuse 5 for the PCM on ignition I get no power do you know if that’s normal?
Thanks for any help
Spaceman210
Postby Matt_403 » Thu Sep 17, 2020 11:03 am
Have you checked under the EJB ive had one before where the wires were corroded underneath the fusebox you might of moved it enough for them to make contact again
Matt_403
Postby BFW01 » Mon Apr 12, 2021 2:59 pm
Did you find out what was causing the fault? As my babs been doing identical since Aug when it had a rebuild
BFW01
Postby sherwoodcycles » Sun May 07, 2023 4:53 pm
You might also want to try creating a temp ground for the terminal on the relay. Looking down at it...the topright tab. The bcm creates this earth. If you have 12v on the furthest left tab, 12v on the bottom right tab, then try the ground test
Greeny
sherwoodcycles
Postby sherwoodcycles » Mon May 08, 2023 11:32 pm
Sounds like you might want to join the 'funked bcm ground for low pressure fuel circuit club' hopefully not but it does sound like it
Greeny
sherwoodcycles
Return to Transit Custom
