rossco_pb wrote:Had a dreaded power train fault light appear and van went into limp mode. Pulled over, stop and start and all good until floored it on a hill and faulted again so dropped into nearest Ford and $98 later told is P2563 which is Turbo boost control position sensor circuit. They cleared code - pcm all up to date and no other problems. Was advised that it can be an issue with this model vehicle (2008, LWB, 140ps engine) but it should be ok for maybe a year or so if lucky. Ford approach to repair is to replace whole turbo assy. Van has only done about 62k km (motorhome).
After code cleared I was not able fault again so I asked Ford had they tweaked something - they say no, just read and cleared code. Strange...
So, did some research on net and found crowds that refurbish the Garrett control unit but all in the UK - but me in NZ so took it apart to see what gives and found worm drive gear assy grubby due to wear of the worm (no lubrication) and lots of end float which is turn translates into actuator arm freeplay. Removed the motor and gear assy and shimmed it to remove end play and lubricated with silicon grease and reassembled and reinstalled and still cannot make it fail. Actuator arm into turbo very free so does not feel like the vanes sticking...
Installed a boost gauge I had sitting around so I can see what is happening and find that there is always boost present unless decelerating - peaks at about 19lb and then pcm drops it back to the max of 17lb so no apparent problems there.
What I don't understand is the Ford take on the issue, ie that sometimes these glitches occur and at some point in the future it will fail... Does anyone have any insight as to what it may be that is causing this type of issue with this particular model of transit (and Garrett actuator) as from what Ford said it is quite common?
Glad to have found this! I'm having the same issue at 208Kms on my motorhome also. Spoken to dealership and they have said its $8.5k fix to replace the turbo charger, so im keen to investigate this idea further! Did you have to remove the TC to complete this work ??
