Fitting reverse camera to 2020 sync 2.5
Re: Fitting reverse camera to 2020 sync 2.5
Postby Slushydragon » Thu May 13, 2021 3:27 pm
sparkie1984 wrote:2018 mate.
What does the camera look like externally? Does it look like the Ford one?
The best cameras are the wedge as you can change settings on them and angle.i cant use a high level as im planning a spoiler.
If your rocking the Sync3, you would need the other harness for around £35 and coding.
I think the main stealers fit the OEM for just under £500
Slushydragon
Postby sparkie1984 » Thu May 13, 2021 4:09 pm
Plenty of pictures please :D
sparkie1984
Postby Slushydragon » Fri May 21, 2021 11:21 am
I can now confirm this is working ,
I had to run RCA cable behind glovebox to £12 Focus harness behind screen,easy job.
I can confirm the coding required for anyone else doing this,will post it up later,its a matter of changing the digit 1 to digit 2.
Slushydragon
Postby R8khn » Sun May 30, 2021 10:47 am
Would also like this fitted to a 2020 custom limited. Any recommendations in London for suppliers and installers
R8khn
Postby Slushydragon » Sun May 30, 2021 11:16 am
Its fairly simple to install,
Need Ntsc camera,£12 harness and an Elm237 for £15 if you don't already have one
Slushydragon
Postby R8khn » Sun May 30, 2021 11:35 am
Slushydragon wrote:Its fairly simple to install,
Can you provide links to any of the components please?
R8khn
Postby Slushydragon » Sun May 30, 2021 2:31 pm
First ensure you have sync 2.5,
The harness is from amazon for 2020 focus camera harness, its the sqaure plug.
I got my ntsc parkvision camera also from amazon.
You can power the camera from the accessorie behind driver side rear l light cluster
Slushydragon
Postby R8khn » Sun May 30, 2021 4:47 pm
Slushydragon wrote:First ensure you have sync 2.5,
Thank you for the info
R8khn
Postby Slushydragon » Sun May 30, 2021 7:31 pm
Here is the coding required for sync 2.5
727-08-02:
xxxx xxxx xX
Change X to
2 for Non-NA layout
3 for NA layout
4 for Non-NA layout with Split View
NA = North America
Basically you change the digit 1 to 2
Slushydragon
Postby Jay-jay22 » Sun Aug 01, 2021 9:43 pm
Slushydragon wrote:Here is the coding required for sync 2.5
727-08-02:
xxxx xxxx xX
Change X to
2 for Non-NA layout
3 for NA layout
NA = North America
Is there anything else must be done I was trying to get it to work with all the stuff you done but I just get a blank screen do you you have any pictures of your codes for that colum
Jay-jay22
Postby Jay-jay22 » Sun Aug 01, 2021 9:44 pm
Or has anyone else got this working
Jay-jay22
Postby Slushydragon » Mon Aug 02, 2021 2:48 pm
Hey
You should get a blue screen after the coding without fitting the camera,
You should be able to find the thread on forscan forum listing the coding,i got it from there,
Theres also other guys with this working on there.
Ensure you have a Ntsc camera and its powered.
Moz
Slushydragon
Postby Slushydragon » Mon Aug 02, 2021 2:53 pm
727-08-02:
xxxx xxxx xX
Change X to
2 for Non-NA layout
3 for NA layout
NA = North America
Are you changing the last digit to "2" ?
Slushydragon
Postby Stuartbrown06 » Tue Feb 01, 2022 9:15 am
Great thread, assumed with my van being a 2020 the latest sync would be the sync 3, bit backwards the latest one being the 2.5?!
I’ve just ordered the focus loom adapter for £12. Cheapest transit one I found was £85, going to look for a ntsc high level brake light camera now and hopefully get this up and running tomorrow :D
Didn’t fancy paying the stealers £500
Stuartbrown06
Postby Stuartbrown06 » Wed Feb 02, 2022 10:02 pm
Ive fitted the camera, loom adapter and plugged it in. Ive tried to code it but when I enable the camera in the BCMii module nothing changes when I select reverse? I still just get the parking sensor image
Forscan lets you enable the camera in 'easy' mode but if I go into the BCMii As Built option I don't have 727-08-02. All of the codes seem to begin with 726.
Any one got any ideas?
Stuartbrown06
Return to Transit Custom
Users browsing this forum: dwlawson
