Speed limiter removal
Postby MattyTramp » Fri Apr 09, 2021 3:07 am
Can anyone recommend somewhere to get a speed limiter removed in Sheffield? Can any garage do this? And how much should it cost roughly?
I have just bought a 2011 Mk7 Transit and the dealer neglected to mention the limiter - the cheeky blighter!
MattyTramp
Re: Speed limiter removal
Postby knobby1 » Fri Apr 09, 2021 10:45 am
MattyTramp wrote:Can anyone recommend somewhere to get a speed limiter removed in Sheffield? Can any garage do this? And how much should it cost roughly?
Is it a minibus..?? If so you may not be able to.
If not, download Forscan and do it yourself.
Postby MattyTramp » Fri Apr 09, 2021 10:52 am
Knobby1 It’s not a minibus - crewcab transit ex-fleet vehicle.
Downloading Forscan is a fine idea, however I have no clue what I would need to do, so that is out the window!
Cheers!
MattyTramp
Postby knobby1 » Fri Apr 09, 2021 9:26 pm
MattyTramp wrote:Knobby1 It’s not a minibus - crewcab transit ex-fleet vehicle.
Cheers!
A garage will charge up to 75quid just to plug in, let alone fix anything, you can set yourself up with Forscan for less than 20....then you'll have it for the life ov your Transit.
Forscan is very user friendly too.
Postby Deke » Sat Apr 10, 2021 11:16 am
Based on the advice of Knobby1 and others I downloaded Forscan last weekend and hooked it up with an interface from Amazon. Forscan was free and the usb interface was about £17. Well worth the effort, I was able to read my faults codes off straight away.
Forscan is pretty user friendly, so if it can remove the speed limiter it’s worth getting.
Deke
Postby crapmetal » Mon Apr 12, 2021 2:28 am
I too recommend forscan, it's already saved me hundreds in garage costs and was very convenient for coding a spare key. If you need help with it then ask here but there is plenty of info on here and the forscan forum.
crapmetal
Postby Crazyjnz » Sun Jun 13, 2021 12:50 pm
what is the procedure in forscan for removing the speed limiter? I have looked but cant seem to find how/where to do it.
Crazyjnz
Postby crapmetal » Sun Jun 13, 2021 6:47 pm
Have you actually had a play around with it plugged into the van?
I can't remember the exact step by step but it was easy to use if a little stressful when it rewrites your configuration.
https://images.app.goo.gl/3qv6xAXcC7jE3kdt6
If you can find this screen then you've got it. I think it was in the bcm but I did it a couple of years ago now.
crapmetal
Users browsing this forum: Bing [Bot], Google Adsense [Bot]
