Need to drill out a broken bolt
Postby johnski » Thu Jun 17, 2021 5:54 pm
So 1 of the bolts on rear stub broke when I was trying to remove it (mk7 tourneo), I now need to drill this git out, can anyone recommend a good drilling out bit?
I've got metal drill bits but is there anything better?
10 Plate Transit Euro 4
johnski
Re: Need to drill out a broken bolt
Postby Chris21r » Thu Jun 17, 2021 6:49 pm
If the bolt sheared its likely seized.
You'd be as well having a nut welded on the broken section and heating the threads first to attempt to remove. You can drill afterwards if unsuccessful.
Chris21r
Postby ned » Thu Jun 17, 2021 6:50 pm
How much of the bolt is protruding? Is there enough to weld a nut on.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby johnski » Thu Jun 17, 2021 7:42 pm
its flush on the front and flush on the rear
johnski
Postby Mike » Thu Jun 17, 2021 8:27 pm
Centre punch it and use a cobalt drill bit.
Mike
Wind up merchant!
Postby andz327 » Sun Jun 20, 2021 11:27 pm
With the stub off can you still not get enough to weld nut onto?
Sent from my SM-G975F using Tapatalk
andz327
Return to Transit Talk
