What did you do to your connect today?
Re: What did you do to your connect today?
Postby Altransit » Tue Oct 12, 2021 2:40 pm
blue estate wrote:The drivers side light was cracked at the top any way so needed replacing
Fair doos :mrgreen:
Postby blue estate » Sun Oct 17, 2021 3:38 pm
Few little bits today ,
Changed the high level brake light , cleaned it out :oops: , swapped back to the Ford radio , swapped the passengers seat from a fold up one to a proper seat , change the key and separate remote for the all in one type
blue estate
Postby Kenton » Sat Nov 13, 2021 6:20 pm
Replaced the crank shaft oil seal, as it has given up in catastrophic style and sprayed oil everywhere!. Had to replace the auxiliary belt as that had also partly shredded because of the oil ingress. We realised when removing the crank pulley, that one section of the aux belt had stripped and wrapped around the rear of the pulley... A seal, belt, oil change, and steam clean later, plus a test drive to ensure the leak was gone, and she's back on the road once again :D 8)
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby metalworker0 » Sat Nov 13, 2021 8:29 pm
Kenton wrote:Replaced the crank shaft oil seal, as it has given up in catastrophic style and sprayed oil everywhere!. Had to replace the auxiliary belt as that had also partly shredded because of the oil ingress. We realised when removing the crank pulley, that one section of the aux belt had stripped and wrapped around the rear of the pulley... A seal, belt, oil change, and steam clean later, plus a test drive to ensure the leak was gone, and she's back on the road once again :D 8)
all the bits you bought for that; seals gaskets etc and timing cover alignment tool .some would be ford and expensive - I don't envy you. well i do for you having the tools 8)
Postby Kenton » Sun Nov 14, 2021 8:25 pm
Long time good friend of the family has a garage, so very fortunate on that count. Only parts required were belt, seal, oil and filter. None were expensive from frauds believe it or not. Didn't need the timing tool as it was the auxiliary belt, not the timing belt :D
ST 17" alloys
Focus ST170 seats
Sport spoiler
Blacked h/lights
Side bars
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby blue estate » Sat Dec 11, 2021 12:41 pm
Got a new MOT :D
Just gotta keep an eye on the brake lines
blue estate
Postby Bourbon25 » Mon Jan 10, 2022 4:46 pm
Drove it home from the dealers! Just got in. nightmare trying to tax it on-line, So I had to go to the post office and do it the old fashioned way.
Bourbon25
Postby Bourbon25 » Fri Jan 14, 2022 7:53 pm
Started putting a reversing camera on it and sorting out insulation of the rear.
Bourbon25
Postby Bourbon25 » Fri Jan 21, 2022 5:51 pm
reversing camera fitted and working. Thank to the forum for identifying the right colour/s for the reversing light.
Bourbon25
Postby Kenton » Fri Jan 21, 2022 6:25 pm
Great result! Happy for you m8 8)
ST 17" alloys
Focus ST170 seats
Sport spoiler
Blacked h/lights
Side bars
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Bourbon25 » Sun Jan 23, 2022 8:13 pm
Kenton wrote:Great result! Happy for you m8 8)
Thank you. Now onto lining it out and designing a bed for it,
Bourbon25
Postby blue estate » Sun Jan 23, 2022 9:30 pm
Been out and about in it today and ordered a new thermostat and housing for it for TPUK £17
blue estate
Postby overdraft » Tue Jan 25, 2022 5:11 am
I crammed my track bike into my new-to-me 2011!
overdraft
Postby blue estate » Tue Feb 08, 2022 5:11 pm
Fitted the new thermostat and spare wheel carrier , also fitted the plastic bits around my 07on intercooler
blue estate
Postby StuBaker » Thu Feb 17, 2022 10:18 pm
I managed to stuff up my PCM/ECU :oops:
StuBaker
