Windscreen Removal???
Postby Luke » Sat Dec 03, 2005 4:05 pm
Im looking at putting my mk3 shed on the road but the windscreen is cracked badly!! :( my mk4 shed has a good screen in it - so i'd like to swap it over!!
Any tips on getting the screen out in one piece is it possable??
:D
Postby MrMPuk » Sat Dec 03, 2005 4:22 pm
Good luck mate! All I can say is take your time and make sure you cut all the way round it! Try cutting from the inside with a long bladed knife.
Postby rover » Sat Dec 03, 2005 5:08 pm
Never bother doing it myself now, I did one once and made such a mess of the rubber.
The chap I call on for windscreens only charges 60 quid or so for a Tranny windscreen.
rover
Postby MrMPuk » Sat Dec 03, 2005 5:17 pm
Yeah but Luke is a tight northerner! :P :lol:
Postby FredTransit » Sat Dec 03, 2005 5:41 pm
rover wrote:Never bother doing it myself now, I did one once and made such a mess of the rubber.
isn't the Mk3 screen bonded in? Or is that only the later ones?
FredTransit
Mk2 Trannyist
Postby Luke » Sat Dec 03, 2005 5:49 pm
rover wrote:The chap I call on for windscreens only charges 60 quid or so for a Tranny windscreen.
£60 :shock: thats 60 times more than the van cost!!! :D
MrMPuk wrote:Yeah but Luke is a tight northerner! :P :lol:
mate its being eco-friendly!! :wink: :lol:
FredTransit wrote:isn't the Mk3 screen bonded in? Or is that only the later ones?
yeah i was thinking of using silkaflex to bond it in!!! :?
Postby rover » Sat Dec 03, 2005 6:40 pm
Yeah, the screen fitters use a razor sharp 'Hooked thing'(<official name :lol: ) to break the bonding without damaging the rubber surround, I thought I could get away with using the 'carpet cutter' blade from a Stanley knife......wrong....very very wrong!
rover
Postby Boycie » Sat Dec 03, 2005 7:31 pm
We use cheese wire at work mate!!
Then the RAC man fits them for us, you 'have' to use special bonding sealer.
In fact, I shall be able to tell you exactly how to replace the 'screen soon because my Mk4 needs a new one.... after some local b*stard decided it would be fun to throw a stone at my perfect, original screen :x
Boycie
Postby Luke » Sat Dec 03, 2005 7:37 pm
I was thinking about getting some wire - handle either end, and heating it up with a heat gun then melting the sealer in a cutting action - 2 men - one inside one out - with the heat gun :?
get it! :?: :idea: :? :lol:
would this would work??
Postby MrMPuk » Sat Dec 03, 2005 7:41 pm
Sounds like a good idea, everything other than the heat guns that is!
Postby Luke » Sat Dec 03, 2005 7:47 pm
MrMPuk wrote:Sounds like a good idea, everything other than the heat guns that is!
whys that then?
Postby Boycie » Sat Dec 03, 2005 7:48 pm
Yup, that's the way to do it!!
Don't use heat tho! Once you get going, it'll be out in 3 minutes flat. I can do an Astra/Cavalier one on my own, but it's a whole lot easier with someone the other side!
Boycie
Postby Luke » Sat Dec 03, 2005 7:52 pm
problem is i dont have any cheese wire - i was thinking of pointing the heat gun on the wire - not on the rubber! :?
:D
Postby rover » Sat Dec 03, 2005 8:03 pm
Luke wrote:problem is i dont have any cheese wire - i was thinking of pointing the heat gun on the wire - not on the rubber! :?
:D
$ainsburry's>dehli counter>large lump of wood>=Free Cheese Wire :lol:
rover
Postby WINDSCREENGUY » Sat Dec 03, 2005 8:28 pm
i would ask a windscreen fitter how to do it
formally grey van man.
WINDSCREENGUY
previously grey van man
