Unfortunately now the rack is fitted it interferes with the reverse park sensors which I did wonder if it would happen but obviously it doesn't help
Anyone else done something similar and found a good solution?
pjumeau wrote:I am also searching for a suitable bike rack for barn doors. Is there no a clip on version of this Thule rack which is designed for doors curved at the top? It is difficult to get a definitive answer even from suppliers.
cyclingspongecake wrote:Ok update for anyone wanting to attempt something similar ! I spent several more hours moving the rack up 22 cm so that it now does not interfere with the reverse sensors. The downside is that the advance warning of coming into contact with something is likely to be when I come into contact with somethingHowever the rack is fitted which was a Thule Sport G2 compact. It is not 100% ideal due to the shape of the doors and I can see the lower panel moving when I press down but I believe it will be fine with the weight of a bike or two on it (non e-bike!) and if necessary I can add a bit of support behind the lower bar where there is a gap between it and the door & possibly add a bracing plate inside the door.
FrankMCG wrote:cyclingspongecake wrote:Ok update for anyone wanting to attempt something similar ! I spent several more hours moving the rack up 22 cm so that it now does not interfere with the reverse sensors. The downside is that the advance warning of coming into contact with something is likely to be when I come into contact with somethingHowever the rack is fitted which was a Thule Sport G2 compact. It is not 100% ideal due to the shape of the doors and I can see the lower panel moving when I press down but I believe it will be fine with the weight of a bike or two on it (non e-bike!) and if necessary I can add a bit of support behind the lower bar where there is a gap between it and the door & possibly add a bracing plate inside the door.
Hi, it looks great! Is it possible to mount a hitch rake for 4 bikes(like this) in the same way? I'm afraid that fastenings won’t hold that weight
Thanks in advance
Frank
