Mk7 airbag light removal
Postby FritzZeus » Tue Dec 20, 2022 12:28 pm
Hi
I have fitted new batteries in my van and my airbag light is on, any ideas how I can get rid of this please?
FritzZeus
Re: Mk7 airbag light removal
Postby Punto443 » Tue Dec 20, 2022 1:16 pm
Read the codes and fix the problem.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby M3Stig » Thu Dec 22, 2022 9:15 pm
Punto443 wrote:Read the codes and fix the problem.
that seems like to much effort
just take the bulb out or put some tape over it
M3Stig
Postby gotgcoalman » Thu Dec 22, 2022 11:35 pm
Thought the lights had to work if the corresponding "thing" was fitted.
Eg,l airbag.
Light has to come on and then go off after a predetermined time.you can .......
1, diagnose and sort the problem.
2,take the bulb out and hope the mot bloke doesn't spot it.
3,set the airbag off and see if the light goes out. Argue the toss that no airbag is fitted with#2 at this point.
Are you not a bit worried that a possibly faulty airbag might go off when you're driving?
I'd be shitting it every time I went over a speed hump
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby Altransit » Thu Dec 22, 2022 11:58 pm
gotgcoalman wrote:Are you not a bit worried that a possibly faulty airbag might go off when you're driving?
There's no chance of an airbag going off if the light is on, any fault with the system prevents anything working :)
Postby gotgcoalman » Sat Dec 24, 2022 10:37 pm
Ahh. With you now.
Was always lead to believe (bad info from Rover forum years ago)
SRS light on= possible undesirable deployment of airbags and seat belt tensioners.
Light on means no worky at all
gotgcoalman
