Connect Brake Pedal Pulsing
Postby metalworker0 » Mon Dec 26, 2022 10:07 pm
"erratic signal will make the pedal pulse,usually at low speed just before stopping."
this is happening to my connect
looked at all the diagrams don't see a toothed ring
looked at the hubs ..don't see this toothed ring
i have the sensors
does the hub have to come out to find it ..will taking hub off, destroy the hub?
Re: mk6 rwd ABS kicking in
Postby knobby1 » Mon Dec 26, 2022 10:15 pm
metalworker0 wrote:"erratic signal will make the pedal pulse,usually at low speed just before stopping."
i have the sensors
Pop a wheel off, the toothed (reluctor) ring will be within 1mm of the end of the sensor.
Postby metalworker0 » Tue Dec 27, 2022 1:20 am
i take it you can only see it when you take the sensor out of the hole
all the best..mark
Postby knobby1 » Tue Dec 27, 2022 2:06 am
metalworker0 wrote:i take it you can only see it when you take the sensor out of the hole
all the best..mark
Nope, the front reluctor ring is behind the brake rotor. It looks like a toothed wheel and is pressed onto the inner part of the hub.
Postby Frag » Tue Dec 27, 2022 12:04 pm
Transit connect is different,more like a car setup.
It doesn’t have any kind of toothed ring.
The dust shield part of the wheel bearing is a magnetic pickup.
People have fitted the front wheel bearing the wrong way round in the knuckle then wondered why abs won’t work,or even fitted the non-abs hub,which looks identical (minus the magnetic bit)
Rear hub is same,see this pic.
The brown / red part of inner bearing seal is the abs ring.
https://www.ebay.co.uk/itm/394086582112 ... media=COPY
Frag
Ford Technician
Postby metalworker0 » Tue Dec 27, 2022 12:11 pm
so there is no thoothed ring to corrode and cause this problem then ..so must be the sensors ?
or can rust swarf etc ... magnetically stick to it to cause problems
can this hub be removed without destroying it ...so i can see whats going on
Postby Frag » Tue Dec 27, 2022 12:41 pm
Yes,
Rust,swarf/debris or damage to the surface will cause same ‘issues’….
If you’ve already checked or changed the sensor itself,then it’s likely that ring,you may be able to see it on a front bearing once the driveshaft is removed.
The abs sensor comes down thru top of the knuckle,and fits in the gap left between the ends of the large bearing retaining circlip.
Frag
Ford Technician
Postby metalworker0 » Tue Dec 27, 2022 1:06 pm
can the hub be removed without writing it off .
there is no drive shaft
all the best...mark
Re: Connect Brake Pedal Pulsing
Postby Altransit » Tue Dec 27, 2022 1:36 pm
I've split the topic and re-homed the Connect question, to avoid confusion between two different vans :)
Postby Frag » Tue Dec 27, 2022 1:42 pm
Thanks Al,
We have no relevant details of this vehicle, hence mentioning removal of driveshaft
OP has not stated front or rear,or any details other than it’s a connect….
Frag
Ford Technician
Postby metalworker0 » Tue Dec 27, 2022 1:59 pm
Rear hub/hubs on 2006 connect with drums.
not sure ..if the bearings will destroy themselves when removed
That's the question
in order to check all is well, this hub / Hubs needs to be removed.
lots of grinding / sand blasting went on ...when i de-rusted rear leaf springs and de-rusted parts of rear bodywork .
having said that ...the pulsing pedal was happening even before this. ...exactly how you said ..just before coming to a stop.
This hidden magnetic set-up is new to me ..never come across it before ..all my previous vehicles had toothed rings ...which you could clearly see and diagnose.
thanks for replies so far
Postby blue estate » Tue Dec 27, 2022 5:21 pm
metalworker0 wrote:Rear hub/hubs on 2006 connect with drums.
That's the question
Bearings won’t destroy them selfs as they’re not sealed like the front
MGS5 and MG5
VOLVO FH daily drive
blue estate
Postby metalworker0 » Tue Dec 27, 2022 6:56 pm
OK thanks guys, by the looks of things ..im not ever going to understand what i need to do without having the thing in front of me and doing it.
it can wait 'till the warmer weather.
